Author Topic: Suspension Travel Question  (Read 570 times)
Offline zalion0
« on: February 22, 2022, 01:17:44 AM »
Hi All, I've got another question I was hoping to have some assistance with. I'm taking apart and rebuilding the front forks on my '77 CB750 F2 and there is some chrome pitting on the forks themselves. The pitting appears to on the exposed parts of the forks as opposed to the bottoms. What i'm trying to work out is if the pitting will affect the oil retention or if it is outside the zone of the suspension travel. The shop manual states there is 141.5mm of travel in the forks, but where is this measured from? One fork is in pieces, the other is waiting to be taken apart.
In short, i'm trying to work out if I need to spend £200 on a set of new forks  :'(
Offline BenelliSEI
  • 1969 cb750
Re: Suspension Travel Question
« Reply #1 on: February 22, 2022, 05:24:50 AM »
Travel is usually the biggest number possible. Use the fork leg that is still assembled and measure  from the seal that distance. If that point gets into the chrome “blisters” in your photo, you need new tubes. If not, carry on.
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #2 on: February 22, 2022, 07:35:43 AM »
Remove the cap and push the inner fork tube down into the lower until it stops. If the seal is into the pitting you could be into the pitting at maximum travel when riding.
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
