Author Topic: 1979 CB650 spark plugs  (Read 1006 times)
Offline Scotiabiker79
« on: March 01, 2022, 02:24:40 PM »
So it’s shrove Tuesday.     In my resto project I had the bike running before after carbs rebuilt and oil change and putting the airbox on.  Then it started running horrible when starting
My confession lol.  I finally pulled plugs.  Black carbon.  I bought hotter plugs this afternoon started it and it runs like a gem.
  I forgot the cardinal rule.   Fuel air and spark.
Re: 1979 CB650 spark plugs
« Reply #1 on: March 02, 2022, 09:18:22 AM »
Good to hear ya got it running good. But, black plugs typically indicates a rich running condition, possibly too big [or incorrect] jets.  If you put in a hotter [non stock spec] plug, you may just be compensating for another issue. I'd keep an eye on it.  Good Luck
« Reply #2 on: March 02, 2022, 09:21:51 AM »
Ok cool thanks for the tip.   I put rebuilt the carbs with carb kits from 4 into 1.  I’ll keep an eye on it.  Gonna get the carbs synched in a few weeks at a bike shop.
« Reply #3 on: March 02, 2022, 10:46:07 AM »
Are the carb kits aftermarket? If yes, that could be the issue.  Highly suggest only using Keihin jets, dont bother asking how I know this! Good luck.
« Reply #4 on: March 02, 2022, 11:09:46 AM »
Lol.  Trial and error.  I’m not sure the brand of kits.  I assume it was aftermarket. The new plugs I put in r a 7 which is what the clymer manual says to use for Canadian bikes.  I pulled a plug out and it’s clean as new.  I had 8’s in the motor before.
