Author Topic: time for a new battery  (Read 1200 times)
Offline evinrude7
  • not a kung-fu
  • something to hüsker
« on: March 07, 2022, 03:10:11 PM »
i've had this battery for about 5 years and it finally gave up the ghost.  i'll probably replace it with the same one.  question is, to my knowledge these bikes need a 14 amp hour battery.  why in the description of the battery does it say "xta14AHL-bs  12v 12AH"?  is it a 14 amp hour battery or a 12 amp hour battery?
https://www.batteriesplus.com/product-details/powersports/battery/xtreme/cyla14ahlbsxta?fbclid=IwAR005we5_vxtYg-aHPGl4HhKd9j3nCyOLijmcylG-A2bECnlTXxp5zqK0o0
cb750 k6 - ugly
Offline Kenzo1979
Re: time for a new battery
« Reply #1 on: March 07, 2022, 03:15:22 PM »
12AH is more common.  I have noticed “14” in the model number of some of the AGM’s I’ve seen.  Regardless of the model, look to the specs instead: 12V, 12AH - and the orientation of the polarity for the cables to land at the correct spot.  Not to say you couldn’t use a 14AH battery, but the higher you go in amp hours, usually the bigger the battery gets and then you’ll run into the problem of it not fitting in the battery box.
--Kenzo
** 71 CB500, 74 CB550, 76 CB400F, 77 CJ360t **
Offline Alan F.
« Reply #2 on: March 07, 2022, 03:43:39 PM »
I think 750A used a 14ah unit that was just a little taller than stock.
Also check out www.batterystuff.com
Offline Kenzo1979
« Reply #3 on: March 07, 2022, 04:03:16 PM »
Didn’t mention which bike. I have only come across 12AH.
--Kenzo
Offline Kenzo1979
« Reply #4 on: March 07, 2022, 04:12:25 PM »
Here’s another example of 14AH in the Model number, yet it is 12AH…but whatever your bike calls for go with the specs not the Alphanumeric code. It is kind of dumb though.  Also, that battery is a POS, don’t ever buy one.  Motobatt makes a nice AGM, I also like Bikemaster.
--Kenzo
Online Don R
« Reply #5 on: March 07, 2022, 04:40:27 PM »
  The diehard shown at Advance is BTX14AHL 210cca it's the agm type I'm told they are made at the same plant as the YUASA.
Offline eldar
« Reply #6 on: March 07, 2022, 05:10:40 PM »
Ah is just the capacity. These bikes will run fine with a 7ah battery. It just doesn't have much capacity if you idle or ride at low rpm. Lifespan may also be shorter, but I didn't run the 7ah battery long enough to know, besides powersport batteries can have such varied lifespans anyways.
Offline Kenzo1979
« Reply #7 on: March 07, 2022, 05:20:58 PM »
This is true.  I rode around on a 12V 8Ah non-automotive battery with no issues for a good while.  I did kickstart and use my headlight off switch as much as possible.  Can’t imagine it had great cranking amps.  It was a security type battery with spade connectors that I had to make a couple lug conversion connectors for, but it worked - and pretty well too.  Held me over until I got the replacement I wanted.
--Kenzo
« Reply #8 on: March 08, 2022, 08:56:08 AM »
+1, I like the Scorpion AGM battery.   $58 shipped to U.S.
5 years out of a battery is great, I'm happy to get 3years.
Online Don R
« Reply #9 on: March 08, 2022, 10:24:25 AM »
 I have several of the agm formerly sold at Advance, one is 6 years old and the newest one is 3 years old with a few in between. I was disappointed when they went to Diehard.
« Reply #10 on: March 08, 2022, 10:44:44 AM »
Do you frequently charge the battery?
I hope to get longer life charging the battery every 2nd month during the winter.  1-3 days.
Sometimes in bike season too.
« Last Edit: March 08, 2022, 11:05:39 AM by PeWe »
« Reply #11 on: March 08, 2022, 12:31:29 PM »
5 years out of a battery is great, I'm happy to get 3 years.
I rarely charge the batteries since I can ride year 'round.  Although if I havent ridden a particular bike for quite a while [2-3 months], I sometimes put the trickle charger on it if I plan to ride it that week.
Offline evinrude7
  • not a kung-fu
« Reply #12 on: March 08, 2022, 07:00:08 PM »
5 years and i don't charge it ever
cb750 k6 - ugly
Offline evinrude7
  • not a kung-fu
« Reply #13 on: March 08, 2022, 07:03:15 PM »
PeWe i never charge it
cb750 k6 - ugly
Offline hawaiikid
  • 1975cb400f
« Reply #14 on: March 10, 2022, 12:07:38 AM »
Can anyone recommend an AGM battery that will fit my cb400f ? the local battery supplier says they are not available in my size.
Offline Kenzo1979
« Reply #15 on: March 10, 2022, 04:03:00 AM »
@hawaiikid:
Any AGM replacement for a 12A-A type battery will/should fit.  I have a Motobatt MB12U currently in my 400F.
--Kenzo
« Reply #16 on: March 10, 2022, 04:31:03 AM »
@hawaiikid:
+1 on MotoBatt.  Love everything but the color.  ;D
Offline Kenzo1979
« Reply #17 on: March 10, 2022, 05:12:34 AM »
[quote/]
[/quote]
…Funny you should say, I almost wrote about that in the post.  It’s a great battery, but at the right angle I can see that bright yellow peeking out from between the side cover and the frame. All it takes is a nice piece of black tape or spray paint on the one small section that shows to make it better.
« Last Edit: March 10, 2022, 05:14:37 AM by Kenzo1979 »
--Kenzo
Offline Alan F.
« Reply #18 on: March 10, 2022, 06:48:12 AM »
« Reply #19 on: March 10, 2022, 07:26:54 AM »
@hawaiikid:
+1 ...dont like the yellow!  I use MotoBatt in my Kawasakis  when Scorpions are not available.
Offline jeffg
« Reply #20 on: March 10, 2022, 10:01:12 AM »
Hey Stev-O I remember you you used to bring home a new honda everyday you still collecting more?
« Reply #21 on: March 10, 2022, 01:37:01 PM »
Ha ha...no, I maxed out a couple years ago and lost my [free] storage last year and have been downsizing ever since.  But no worries, I still have a nice collection of Hondas, Kawasakis, a Yamaha and a couple Suzukis for good measure!
Offline evinrude7
  • not a kung-fu
« Reply #22 on: March 12, 2022, 07:12:28 PM »
gonna save a few pennies for the motobatt.  thanks.
« Last Edit: March 12, 2022, 07:20:20 PM by evinrude7 »
cb750 k6 - ugly
« Reply #23 on: March 13, 2022, 12:30:28 AM »
i got seven years out of a motobatt,i want my money back!
Offline evinrude7
  • not a kung-fu
« Reply #24 on: March 13, 2022, 07:18:59 AM »
very good
cb750 k6 - ugly
