Shorai batteries are Lithium Iron, not Lithium Ion: there is a difference.
Our bikes should have the stock mechanical regulators replaced with a solid-state regulator that limits the charging voltage to a preferable 14.4V for best battery life. Rick's has a "lithium specific" unit, which regulates the voltage at 14V, +/- .2V, but the minimum voltage recommended by Shorai is 13.9V, IIRC. The standard Rick's has a voltage of 14.9, which is above the max of 14.8. The OMP adjustable reg Bomber mentions can be set to a desired voltage.
I have been running LiFe batteries since 2011, and Shorai brand batteries since 2017. They don't require "battery tenders" on our bikes, which normally have no parasitic drains and can sit for months before self-discharging to the point where they need to be "topped up"; more modern bikes with computers and other drains are a different story.
Both the Shorai batteries I have now are the same capacity, despite the difference in size, and will easily spin over my high compression 836.
