Author Topic: Another K0 build for/by Magpie/Cliff  (Read 6389 times)
Offline BenelliSEI
  • 1969 cb750
Re: Another K0 build for/by Magpie/Cliff
« Reply #100 on: August 19, 2022, 04:34:01 PM »
Oops! Your post appeared while I was keying mine.....
Congrats! Looks fantastic!
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #101 on: August 19, 2022, 07:03:15 PM »
Beautiful bike, well worth the effort, these bikes can try one’s patience
1973 CB 750 K3
10/72 build Z1 Kawasaki
Offline Magpie
« Reply #102 on: August 19, 2022, 07:56:05 PM »
Thanks guys. Yes it was a test of patience indeed. I had to walk away and sleep on it. The frame was powder coated so the holes were tight and needed reaming out. I mounted 1 and 2 and they were close to lining up. Manipulating the 2 pipes a bit I could get the threads in the hole by kind of screwing it in. I resorted to some persuasion with a 2 lb. sledge and a drift. When there was enough threads showing I put a nut on it and pulled it through that way. 3 and 4, after sleeping on it, I went back to the instructions, translated from Japanese, which said to swing 3 out, put the bolt in it and swing it back in to get the bolt in the hole which worked. It didn't work last night. I held the pipe in place and added 4 and pushed the bolt through. This time it went in and again a little persuasion and it went through. Same drill with the nut. God help me if I have to take them off!
They do look nice.
This bike is kind of an homage to one I crashed and destroyed putting it into the driver's door of a car that ran a stop sign. Purchased the bike July 1969, killed it August 1969. Probably a sandcast.
Cliff.
Offline BenelliSEI
  • 1969 cb750
« Reply #103 on: August 19, 2022, 09:14:23 PM »
I used to work for a guy that always concluded; “if this was simple, anyone could do it!”. Well done.
Online newday777
« Reply #104 on: August 20, 2022, 03:21:52 AM »
Cliff
Have you read this post on fitting the repop pipes making a pipe sleeve to go in the cross over tubes to help line the 2 pipes up?
http://forums.sohc4.net/index.php/topic,126176.0.html
Stu
My current rides
Prior bikes....
Offline Magpie
« Reply #105 on: August 20, 2022, 08:45:08 AM »
Metal crossover tubes come with the David Silvers repop pipes. The pipes come in a Yamiya box. They do help keeping things lined up, just don't forget to install them before mounting the pipes.
Cliff.
