Author Topic: Swing Arm Identification  (Read 906 times)
Offline pjandrew99
« on: March 15, 2022, 04:06:56 PM »
Hi Guys
Please help me identify this swing arm.
Thanks!
Current Projects
Honda CB750K1
Yamaha SR250
Honda SL350 K0
Offline Kevnz
Re: Swing Arm Identification
« Reply #1 on: March 15, 2022, 04:43:43 PM »
Looks very similar to 500\4
Good grammar: The difference between knowing your #$%* and knowing you're #$%*
Offline Rookster
« Reply #2 on: March 15, 2022, 05:32:18 PM »
Looks like 72-76 CB750K
Scott
Offline BenelliSEI
  • 1969 cb750
« Reply #3 on: March 15, 2022, 05:43:02 PM »
Scott
+1 to that.
Offline pjandrew99
« Reply #4 on: March 16, 2022, 02:00:04 AM »
Much appreciated!
My confusion was based on the nut that sits on top of the arm. All the parts diagrams show three metal tabs. I have no idea what the nut or the tabs are for. What is the purpose? Thanks!
Current Projects
Honda CB750K1
Yamaha SR250
Honda SL350 K0
Offline pjandrew99
« Reply #5 on: March 16, 2022, 02:18:16 AM »
This. ????
Current Projects
Honda CB750K1
Yamaha SR250
Honda SL350 K0
Offline Kenzo1979
« Reply #6 on: March 16, 2022, 03:13:03 AM »
Chain guard mount I would imagine
--Kenzo
** 71 CB500, 74 CB550, 76 CB400F, 77 CJ360t **
Offline pjandrew99
« Reply #7 on: March 16, 2022, 03:38:26 AM »
Here is a picture of the metal tabs on my 71 swing arm. Its in the same location as the nut on the later swing arm.
The chain guard on the 71 doesn't come in contact with these tabs.
Current Projects
Honda CB750K1
Yamaha SR250
Honda SL350 K0
Offline pjandrew99
« Reply #8 on: March 16, 2022, 04:12:00 AM »
Yes, I think you are correct. Pictures of the 72-76 CB750 chain guard show a hole where the guard bolts into that nut. I guess the OEM K1 guard clips into those tabs and holds it in place. Obviously, my 71 guard is not OEM. Not surprised! Appreciate the help.
Current Projects
Honda CB750K1
Yamaha SR250
Honda SL350 K0
Offline BenelliSEI
  • 1969 cb750
« Reply #9 on: March 16, 2022, 07:54:11 AM »
Bend up a “U” channel of aluminum about 4” long. Bolt one end down and trim it so your earlier guard snaps into it..... should line up fine?
Offline pjandrew99
« Reply #10 on: March 16, 2022, 08:29:33 AM »
Great! Thanks!
Current Projects
Honda CB750K1
Yamaha SR250
Honda SL350 K0
Online PeWe
« Reply #11 on: March 16, 2022, 08:58:08 AM »
Not CB750 1976. (K6)
It has a slightly different shape closer to where it is attached to frame. The grease nipple sit in the swing arm.
But no problem to use a K2 swing arm on a K6.
My blue K6 has a K2 swing arm.
Offline pjandrew99
« Reply #12 on: March 16, 2022, 11:14:16 AM »
I'll be putting it on a K1. Having some fit issues which I mentioned on another post. Not sure of the reason yet.  Thanks!
Current Projects
Honda CB750K1
Yamaha SR250
Honda SL350 K0
