Author Topic: Painting a 71 Honda frame - suggestions?  (Read 999 times)
Offline gary p.
« on: March 16, 2022, 01:39:17 PM »
As soon as the weather is right, I am going give my frame and other parts a fresh rattle can paint job.  I’ll be grateful to hear your suggestions for what you’ve used and think works best.
Follow up:
Guys, thanks for the suggestions.  I really appreciate them.  Regrettably, I don’t have the budget for powder coat.  Several customers, from my working days, had a powder coat lines and the results are great.
I have two frames and have decided to do one with HF and one with VHT.  I’ll post my result for each when finished.  For now, I have a lot of sanding and prep on all the various painted parts to keep me busy.
My skills are beginner, at best, so I will splurge on getting the tanks and side covers done professionally. Candy Bacchus Olive on one set and Candy Gold for the other.
« Last Edit: March 24, 2022, 12:21:26 PM by gary p. »
Re: Painting a 71 Honda frame - suggestions?
« Reply #1 on: March 16, 2022, 04:15:53 PM »
Love the Rust-oleum Appliance Epoxy.
Offline gary p.
« Reply #2 on: March 16, 2022, 04:56:18 PM »
Mfg. specifies for indoor use only.
Offline gschuld
« Reply #3 on: March 16, 2022, 05:04:55 PM »
https://www.vhtpaint.com/high-heat/vht-roll-bar-chassis-paint
I’ve had good luck with VHT Chassis and Rollbar paint.  Satin black or gloss black.  Same for triples and swingarm, etc.
I let it cure overnight, then make an Easybake oven of sorts with a heavy walled cardboard Fridge box and a few heat lamps bringing temps up to 150 degrees for a harder “post cure”.  Solvents haven’t bothered the finish.
70 and 71 frames(modified a bit) in pic
George
« Last Edit: March 16, 2022, 05:09:50 PM by gschuld »
« Reply #4 on: March 16, 2022, 10:18:19 PM »
  Not a spray can but I liked Imron blitz black in a cheap paint gun, I hang the frame and get all of the light I can. Wet down the floor and spray away. When I'm close to done I thin my paint with reducer and wet down the entire frame as quickly as possible. That melts in the overspray.
  That said, I've used the appliance epoxy as does a friend that restores Simplex bikes. I also like the VHT chassis and roll bar paint. I've used it on bike frames and chassis touch ups on our drag car. I did the cage with it after I peeled off the powder coat with fingernails and a pocket knife.
« Reply #5 on: March 17, 2022, 01:29:30 AM »
No #$%*?  Never knew that.  And no idea why that would be.  There is plenty of stuff I painted with it up to 10 years ago that is holding up perfectly.
« Reply #6 on: March 17, 2022, 07:26:03 AM »
I prefer powder coating...
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #7 on: March 17, 2022, 08:10:34 AM »
I've used POR15 to good effect after media blast. Topped it with their top coat chassis black.
1973 CB 750 K3
10/72 build Z1 Kawasaki
Offline Alan F.
« Reply #8 on: March 17, 2022, 11:29:12 AM »
Don't worry about the appliance epoxy out in the weather, it'll hold up just fine. They've got a stainless steel color that looks great if you're not up to having another black frame.
Offline Bankerdanny
  • Endeavor to persevere
« Reply #9 on: March 17, 2022, 02:39:22 PM »
I used Iron Armor Frame and Grill Paint from Harbor Freight. It is a 99% match to the factory paint.
https://www.harborfreight.com/11-oz-gloss-black-chassis-and-grille-paint-60780.html
Offline Just John
  • Apparently I am a glutton for punishment
« Reply #10 on: March 19, 2022, 03:37:49 PM »
I painted a spare Honda CL360 frame with the Rustoleum Appliance Epoxy as a test.  After painting the frame I let it sit outside in the elements for over a year.  I endured Georgia weather very well including multiple 100+ degree days of full sun and a week long siege of snow and ice.  I think for the money it is a pretty good deal.
Member
AMA
AMCA
VJMCA
Offline Gurp
  • I'm no.......
  • Once was a...
« Reply #11 on: March 25, 2022, 05:49:56 PM »
Painting on a budget you can use a 20 buck electric house sprayer and tractor and implement paint from rural King or tractor supply just thin it down to parts paint to 1 part acetone.
The brand for the paint is Majic. It holds up great.
slow Progress 74 cb550.
Poor boy chop 73 CB500 chop
Future project 77 Cb750 Amen Savior
