I finally got the ride I've been wanting, (sort of) a few miles warm up. Big bumps about toss me off. The short shocks are almost as bad as the stuck Koni's. I made it to the park to break in the new tires and did several horseshoe turns going both ways. I managed to get around quick enough to get into my own smoke, it appears to be blue. The park was great although I did manage to drag the RC pipe a little. That sucked but I forget it's built as a drag bike not a road racer.
Anyway I got on the 4 lane coming home, did 70mph for a couple miles in the heat and opened it up WFO to only 85 or so before slowing and taking the ramp. At the bottom of the ramp it died. When I put a foot down it was oil soaked but I managed to not fall over.
A young guy with a trailer stopped and offered to load it up, I told him thanks, but I thought it would start. After a few minutes I tried a kick start and it seemed tight, the starter motor agreed. I gave it 5 more minutes and it fired up and rode home.
Being an 836 already, I'll need another cylinder and maybe pistons. It has a bolt in frame kit so I can at least check the top end.
Thinking back to when I got it, the rocker cover was loose, that worried me. I described the top end to the PO and he said good, that was the good engine but didn't really remember a lot except it had the RC 315 cam and valve parts in it with the ported head. The cam towers were nice and clean, I used some assembly lube on the top end before running it.
Like every race bike there was a reason they stopped racing it, either something broke or it just wasn't competitive anymore.
