Author Topic: MC must be blocked up  (Read 892 times)
Offline jeffg
« on: March 31, 2022, 01:40:17 PM »
I see the old post from 2013, MO MO and Lucky mention about the second MC hole getting blocked. Lucky say he had to drill one out and that looks like my deal also. Lucky say 0.010 was the size. I just checked all my small bits and my smallest bit is 0.025 can I over size the hole or do I need to get the 0.010 bit?
Re: MC must be blocked up
« Reply #1 on: March 31, 2022, 01:53:39 PM »
 You may just need to bleed the air from the M/C. I had one recently that gave me fits until I loosened the banjo bolt at the top and bled it there.
Offline jeffg
« Reply #2 on: March 31, 2022, 02:06:15 PM »
Hey Don I have the banjo bolt out, and if I put my finger over it and pump it does not build any pressure. I did get GOOD NEWS while I was looking for my small drill bits I found mt 10mm TBAR hahaha
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #3 on: March 31, 2022, 02:14:19 PM »
Are your  piston and check valve in good shape?
1973 CB 750 K3
10/72 build Z1 Kawasaki
Offline Johnie
« Reply #4 on: March 31, 2022, 02:28:52 PM »
That small hole is small for a reason you really do not want to make it larger. I used one strand of a wire wheel and kept at it going circles and it cleared.
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline jeffg
« Reply #5 on: March 31, 2022, 02:53:43 PM »
I took a caliper to every small sewing needle and nothing is that small
Offline eldar
« Reply #6 on: March 31, 2022, 03:50:23 PM »
Get a set of carb cleaning wires. There is a plenty small enough wire in there. They work excellent on jets, too.
« Reply #7 on: March 31, 2022, 04:14:10 PM »
Like Johnie I have done the same exact thing even going so far as chucking that one single strand of stiff wire off a wire brush in my drill and slowly clearing the hole.
« Last Edit: March 31, 2022, 09:14:20 PM by ekpent »
Offline jeffg
Offline beemerbum
« Reply #9 on: March 31, 2022, 08:31:45 PM »
A guitar "E" string is perfect for cleaning that little hole. Steel string of course
« Reply #10 on: April 01, 2022, 09:21:01 AM »
 I had a guitar with a saddle issue, that thing broke #8 E strings every week before I finally fixed it. I should have cut them into pieces and sold orifice cleaning strings. L0L.
