The SOHC/4 World Tour is in under way.
I just rebuilt the rear master cylinder on my 77 750F. The hose from the reservoir to the master cylinder is flared and split on both ends. What kind of hose do I need to replace it?Thanks,John
Is it the same line as a 1975 750F? I believe it is. If they are the same I have a sample one that I use to have copies made by a local hydraulic hose place for me. Try taking yours into a hose place where you live and they should be able to make one for you. Mine have all the DOT markings and look original. Cost around $40-50 I believe. If all else fails I can have one made for you here locally and sent it to you.Sent from my LG-H812 using Tapatalk
