Author Topic: Getting my K0 back on the road  (Read 11447 times)
Offline newday777
Re: Getting my K0 back on the road
« Reply #125 on: August 24, 2022, 07:09:35 PM »
Yes the video works for me.  Congrats on getting it sorted. Have a blast on your ride!
Stu
My current rides
Prior bikes....
« Reply #126 on: August 25, 2022, 07:58:48 AM »
+1 sounds good!  PM sent...
Offline WideAWAKE
« Reply #127 on: August 31, 2022, 04:25:25 PM »
Well I got it out for a first ride the other day and it seems I got a buy of an issue with my clutch. Seems to be draggin. Measured up ok when I put it back together but I’ll get it apart for another look at it.
And thanks to Stev-o I finally got a chain guard! The last piece of the puzzle. A little scrubbing, wet sand and polish and it cleaned up quite nicely. Very happy.
So hopefully I can get it sorted out and ready for good rides this weekend.
« Reply #128 on: September 05, 2022, 08:57:17 PM »
Boy, you've sure done a beautiful job with it, W.A.!
Offline newday777
« Reply #129 on: September 05, 2022, 11:59:56 PM »
Looking at your pictures and videos (end of page 4), your clutch cable looks tight between the handle and your the loop going between the gauges. There should be a little more cable in between there so it isn't so taunt. That might be the factor in your clutch dragging.  Is it routed correctly down below the gauges or is it just a shorter cable length?
Stu
My current rides
Prior bikes....
Offline WideAWAKE
« Reply #130 on: September 06, 2022, 07:07:45 AM »
Thank you Hondaman!
Really appreciate all the help!
Offline WideAWAKE
« Reply #131 on: September 06, 2022, 07:10:36 AM »
Clutch cable is routed correctly and set up by the book.
I didn’t know at the time but it would turn out I had incorrect clutch plates. They were slip plates where the cork was cut at an angle.
Replaced the cork over the weekend and it’s much better now.
Onto the next little issue haha.
Offline newday777
« Reply #132 on: September 06, 2022, 07:12:36 AM »
 8) good find
Stu
My current rides
Prior bikes....
Offline WideAWAKE
« Reply #133 on: September 06, 2022, 07:31:48 AM »
Next issue to sort out…
A bit of a flat at around 3-5000 rpm. It’s not major, but it’s there.
Gonna raise my needles one position and see if that helps.
Adjusting these carbs is quite a pain compared to all my twins haha.
Offline WideAWAKE
« Reply #134 on: September 06, 2022, 07:32:59 AM »
8) good find
I’ll credit Hondaman’s book haha.
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #135 on: September 06, 2022, 07:51:40 AM »
Hondaman's book is the go-to book!!!
1973 CB 750 K3
10/72 build Z1 Kawasaki
« Reply #136 on: September 07, 2022, 09:18:30 AM »
Great job Mark!  Nominated you for BOTM...
http://forums.sohc4.net/index.php/topic,180400.0.html
Offline WideAWAKE
« Reply #137 on: September 07, 2022, 12:15:36 PM »
Appreciate that Stev-o!
…And please for give my ignorance but what the heck is “bike of the month” haha.
I see it all the time here, tried to search and see what it was but could never quite figure it out.
Nominated bragging rights??? Haha
« Reply #138 on: September 07, 2022, 01:04:09 PM »
Yes, bragging rights!
We nominate bikes and typically two bikes duke it out, the members vote and 1 bike is the winner!
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #139 on: September 07, 2022, 02:56:51 PM »
I love it! Beautiful bike.
Bike of the month indeed.
On small detail, look at the left side cover, wing is facing rearward. Easy to fix.
1973 CB 750 K3
Offline WideAWAKE
« Reply #140 on: September 07, 2022, 03:54:09 PM »
Do they go on the opposite way???
I tried searching for a direction but couldn’t find anything conclusive.
Thank you for pointing that out!! I’ve been fascinated with all the little details of these bikes, the changes, and nuances.
And while I may have moved the paint gun and turned the wrenches, here we are again as a reminder it was certainly a group effort.
« Reply #141 on: September 07, 2022, 04:30:01 PM »
Yes, the Wing should be "flying into the wind", or at least that's the way I remember it. Good catch Maui...
Offline WideAWAKE
« Reply #142 on: September 08, 2022, 03:09:21 PM »
Took it for a decent ride today.
Sorted out my flat spot - turns out one of my exhaust lances was a little loose, stumbled across it by luck. Tightened it up, no more flat spot.
BUT I got on it pretty good and it seem to flat line around 6k in 5th gear.
I am running 110 mains but maybe I push em to the 120 they came stock with?? I’m not running baffles.
I’m pretty sure it’s been suggested that with modem gas a 110 is the ticket, but nonetheless Im flat lining.
And some proper pics now that it’s all finished up.
Offline WideAWAKE
« Reply #143 on: September 08, 2022, 03:11:13 PM »
More
« Reply #144 on: September 08, 2022, 04:00:32 PM »
Why no baffles?  I'd put the 120's in.
Those agaves look awesome, you making tequila over there?!!
Offline WideAWAKE
« Reply #145 on: September 08, 2022, 04:32:26 PM »
Well I got no baffles cause there were none in there when I got it haha.
Figured I’d run it and see if I like it.
I’ll probably get some baffles here shortly.
I’ll get some 120s on order and see what they do.
The agave is my neighbors, I’m waiting for the stocks to shoot up so I can build some surfboards out of em!!! The stocks are a nightmare to work with but are beautiful once done.
I build a lot of board using local woods and old growth from around town.
« Last Edit: September 08, 2022, 04:34:16 PM by WideAWAKE »
Offline newday777
« Reply #146 on: September 08, 2022, 04:39:28 PM »
Nice looking board! Is that a long board?
Where in CA are you? I have gone to Oceanside for the winter's since 06.
You actually use agave in the boards?
Stu
My current rides
Prior bikes....
Offline WideAWAKE
« Reply #147 on: September 08, 2022, 05:19:05 PM »
That my 11’4 gun. Made for big waves.
I’m on the central coast (pismo beach area). We have a fair amount for 15-20ft surf in the winters around this area if you know where to look.
As for agave…
Yes, when the sticks shoot up, the plant is dead.
It can be harvested, dried and used to build a boards. Very light.
« Reply #148 on: September 08, 2022, 08:15:50 PM »
A question for ya:
what gearing (sprockets) does it have? The K0 cam expected to 'feel' the 16T/45T or 17T/48T sprockets, and if it now has the 18/48 that is commonly sold these days as "OEM gearing", it is too tall for this cam. Dropping the ratio back to original (17/48 lasts longer) wakes them up nicely.
For the long-distance riders:
in order to be able to "pull" taller gearing (like I do with mine, now) you need a different cam (late K5 or K6 - mine is K6 - with the steep closing ramp on the intake valve lobes), some head chamber work (hemi, reduced to 21.4cc), and leaner jets with deeper float bowls. Mine will pull the 19T/48T combination to 105 in 5th gear, but will do 115 in 4th. The tradeoff is the nice "cruise" feeling in 5th when riding places like...Kansas...Nebraska...eastern South Dakota or Colorado...  ;)
Offline WideAWAKE
« Reply #149 on: September 08, 2022, 09:08:32 PM »
Good question!
Just counted.
17/45.
That would explain a lot.
Time to hunt down a sprocket.
