Author Topic: Puller?  (Read 884 times)
Offline amitr0
Puller?
« on: April 03, 2022, 10:12:45 PM »
Any one knows where I can get this? I guess it is a puller tool but googling puller gives me the traditional 3 hooked ones.
I need this for a specific diameter as well, but which knowing what the heck it is called, it is hard to search. If anyone has links to buy it, please share.
Re: Puller?
« Reply #1 on: April 03, 2022, 10:41:48 PM »
 What does it pull?
Online dave500
Re: Puller?
« Reply #2 on: April 03, 2022, 10:45:46 PM »
magneto flywheel puller,they come in various sizes for chainsaws dirt bikes etc,some have two sizes one each end,just reverse the pressing bolt in it.
Offline amitr0
Re: Puller?
« Reply #3 on: April 03, 2022, 11:00:10 PM »
Where do I buy them? Are they a set? Here is a picture of the bolt diameter(no idea about thread pitch)
Should i be looking a 16mm or a 17mm version?
Re: Puller?
« Reply #4 on: April 03, 2022, 11:32:37 PM »
Whats it on? Looks a bit like and old Yam dynostart in which case i think its just a bolt that screws in, bottoms on the end of the crank taper and pulls the rotor, like the 750
Offline bustech51
Re: Puller?
« Reply #5 on: April 03, 2022, 11:44:03 PM »
Google the size you need and then magneto puller.
Sent from my LG-H812 using Tapatalk
Re: Puller?
« Reply #6 on: April 04, 2022, 02:28:16 AM »
Be carefull with the magneto puller the bolt might be small enough to go into the end of the shaft instead of pushing on it
Offline MauiK3
  • A K3 is saved
  • Old guy
Re: Puller?
« Reply #7 on: April 04, 2022, 07:58:50 AM »
I got a set from Amazon
1973 CB 750 K3
10/72 build Z1 Kawasaki
Offline Alan F.
Re: Puller?
« Reply #8 on: April 04, 2022, 08:30:43 AM »
One tip is if you have a collection of rear axles from other bikes, try them before spending on a puller like the one pictured. As long as the threads are correct it'll do the job.
Offline BenelliSEI
  • 1969 cb750
Re: Puller?
« Reply #9 on: April 04, 2022, 09:41:22 AM »
My son bought me one for the Honda Z50 engine I was rebuilding (for him). It’s double ended for two sizes. Maybe checkout a Z50 website and see what sizes they are? From memorial, I think the outer portion was a reversed thread? Is yours?
Offline amitr0
Re: Puller?
« Reply #10 on: April 05, 2022, 12:32:36 AM »
That hack did occur to me but couldn't find an M16x1. 5. Will try the H/w store next
Offline amitr0
Re: Puller?
« Reply #11 on: April 05, 2022, 12:33:23 AM »
A link would he very helpful. Thanks
Offline amitr0
Re: Puller?
« Reply #12 on: April 05, 2022, 12:34:24 AM »
Not sure what a yam dynostat is...
Offline amitr0
Re: Puller?
« Reply #13 on: April 05, 2022, 12:36:33 AM »
Great point about the reverse threading, will have to check tomorrow
Re: Puller?
« Reply #14 on: April 05, 2022, 05:09:50 AM »
On some of its tiddlers Yamaha used a dynamo type generator that could be fed power to make it a starter motor hence dynostart
Online Flyin900
Re: Puller?
« Reply #15 on: April 05, 2022, 06:49:52 PM »
If it is a standard bolt style without reverse threads etc I just buy the correct large bolt from Bolts Plus here for about $5 vs $20 for a so called rotor puller bolt that is the same thing.
Most are 16mm X 1.5 TP with some larger maybe M18X 1.5 TP as I have a few sizes in the tool box. Thread it into the rotor snug against the crankshaft and a decent tap and maybe another half turn on the bolt and off pops the rotor.
1978 CB550K - Super Sport
1982 CM450A - Hondamatic
1982 CB900C - Custom
1983 CX650E - Eurosport
