Author Topic: any differences in the unicorn mounts?  (Read 658 times)
Offline Shtonecb500
    • Youtube profile
« on: April 13, 2022, 05:28:51 PM »
Are there any differences in the unicorn mount or just the gauges and orientation of instrument lights?
Im only interested in the green face ones after the blackface k0 but I dont want to pay for some and have the wrong triple.
« Last Edit: April 13, 2022, 07:05:46 PM by Shtonecb500 »
73/74'' CB500/550 resto-mod - sold
75' 750f 91' cbr f2 swap cafe - mock up
74' 750 chopper hardtail - complete - sold
74' CB750/836kit - Black mix & match - daily rider - always tweaking
71' cb500 K0 survivor - complete
71' K1 - CANDY GOLD/BROWN Winton kit - in process
Re: any differences in the unicorn mounts?
« Reply #1 on: April 13, 2022, 06:08:40 PM »
    The gauges with the indicator lights need to be mounted in a rhino horn triple, The 72 has different gauges and I believe a one year only mount system.
    The top triples all swap except the F which has a different offset.
    Anything for or with a rhino horn mount will be expensive, partly because the rhino horn mounts are prone to breaking.  69/70 and 71 gauges also bring top dollar.
Offline Rookster
« Reply #2 on: April 14, 2022, 11:42:58 AM »
There are some slight differences between the unicorn top trees.  The earliest ones have a narrower unicorn and it is at a different angle than the later ones.  There was also a change in the pinch bolts on the 1972 version.  The unicorn is a poor way of mounting the gauges as they will buzz with higher rpm.  The later rubber cup mounts were better for the gauges.
Scott
Offline BenelliSEI
  • 1969 cb750
« Reply #3 on: April 14, 2022, 04:52:16 PM »
Scott
An old trick (I just used it on my latest project) is to add a wide, black rubber band, around the facorty rubber mount. It adds a layer and limits the “rattle”. If you find the right width, it can’t be seen.
