Author Topic: More Cam Timing  (Read 1553 times)
Offline Rocketman
More Cam Timing
« on: April 24, 2022, 12:36:33 PM »
Putting my 550 back together after an off season refresh.  I have timed my cams before, but was never sure when making changes whether to advance or retard the cam.  So, I did both and noted the changes.  Now I know which way to rotate the cam to get the result I want.  There are detailed discussions of cam timing on the forum and each cam manufacturer also has instructions on their websites. Here are some pictures of how I do it.
Using a piston stop and degree wheel to find Top Dead Center.  The degree wheel is mounted to the original rotor bolt by drilling and taping a 6mm hole in the end.  There is less chance of a valve hitting the piston stop if this is done before the rocker assembly is mounted.
A flat piece of stock is needed for the base of the magnetic dial indicator holder.
I like to mount the dial indicator so that the face is visible while turning the crank from the right side of the machine.  I remove all lash so the valve clearance is zero and rotate the crank to 1mm (.040") of lift.
Hear are the specs for the cam I am using.
Since I have been using this cam I was able to install it and line it up with the witness marks on the sprocket.  My first attempt looked like this.
Intake  0 lash  1mm lift
23.5° BTDC
55°    ATDC
180°
258.5/2 = 129.25 – 23.5 = 105.75°
Exhaust  0 lash  1mm lift
52°  BBDC
24°  ATDC
180°
256/2 = 128 – 24 = 104°
Advancing the cam causes the intake number to increase and exhaust to decrease.
Intake
19° btdc
59.5° atdc
180°
258.5/2 = 129.5 – 19 = 110.25°
Exhaust
47 bbdc
29 atdc
180
256/2 = 128 – 29 = 99°
Retarding the cam causes the intake number to decrease and exhaust to increase.
Intake
28° btdc
50.5° atdc
180°
258.5/2 = 129.25 – 28 = 101.25°
Exhaust
56° bbdc
20° atdc
180°
256/2 = 128 – 20 = 108°
Where I ended up.
Intake
24.5° btdc
55° atdc
180°
259.5/2 = 129.75 – 24.5 = 105.25°
Exhaust
53° bbdc
23.5° atdc
180°
256.5/2 = 128.5 – 23.5 = 104.75°
Not exactly as called for on the cam card, but as close as I could get it.  The differences could be due to measurement error or manufacturer error.
I then set the lash at .004 IN and .005 EX to see what effect that has on timing.  It did have a very small effect, but again that could be measuring error.
Intake
23° btdc
53° atdc
180°
256/2 = 128 – 23 = 105°
Exhaust
50° bbdc
20° atdc
180°
250/2 = 125 – 20 = 105°
Offline flatlander
Re: More Cam Timing
« Reply #1 on: April 24, 2022, 12:59:24 PM »
that looks very good. i don't think anyone can get more accurate than that!
Re: More Cam Timing
« Reply #2 on: April 24, 2022, 01:02:18 PM »
Done & done! Obviously that one does the job but one suggestion for the future, look for a larger degree wheel, larger the better. It will simply help you with accuracy.
Did you need to replace anything in your refresh?  When is your first outing?
Re: More Cam Timing
« Reply #3 on: April 24, 2022, 01:48:33 PM »
Head was checked over Brent. New springs and exhaust valves....pulled great vacuum on the Serdi....good to go.👍
Offline Rocketman
Re: More Cam Timing
« Reply #4 on: April 25, 2022, 08:18:06 AM »
All that is left is to seat the rings.  Will do a 3 short runs on the stand and then 3 progressively longer runs on a go kart track.  Can’t really get much out of 1st gear, but the acceleration and de-acceleration in 1st loads the rings and seems to do a good job seating them.  Best of all the track fee is $10 for the day!  First race on the schedule is Heartland in Topeka, KS with AHRMA at the end of May.  Shooting for New Jersey in June and Mid-Ohio in July.  Barber with AHRMA is in October, so looking for something in between.  Wish Mosport was still at the end of August.
« Last Edit: April 25, 2022, 07:37:14 PM by Rocketman »
Re: More Cam Timing
« Reply #5 on: April 25, 2022, 01:55:33 PM »
All that is left is to seat the rings.  Will do a 3 short runs on the stand and then 3 progressively longer runs on a go kart track.  Cant really get much out of 1st gear, but the acceleration and de-acceleration in 1st loads the rings and seems to do a good job seating them.  Best of all the track is fee is $10 for the day!  First race on the schedule is Heartland in Topeka, KS with AHRMA at the end of May.  Shooting for New Jersey in June and Mid-Ohio in July.  Barber with AHRMA is in October, so looking for something in between.  Wish Mosport was still at the end of August.
I am planning to be at New Jersey in June Martin.
Re: More Cam Timing
« Reply #6 on: April 25, 2022, 02:52:26 PM »
Hummm, Jersey in June. What's the date?
Mosport is Aug 5-7th.
Offline slikwilli420
  • Master of Disaster
Re: More Cam Timing
« Reply #7 on: April 25, 2022, 05:34:53 PM »
June 16-19 Brent. I'll be there with George as well. That's means you have to be there! SOHC reunion!
Offline grcamna2
Re: More Cam Timing
« Reply #8 on: April 25, 2022, 09:27:09 PM »
subscribed
75' CB400F/'bunch o' parts'
Offline Ramrod_Racing
Re: More Cam Timing
« Reply #9 on: April 27, 2022, 07:19:28 AM »
Well shoot. I'm planning to skip NJ this year to spend all my money out west
Re: More Cam Timing
« Reply #10 on: April 27, 2022, 11:01:00 AM »
That's a tough call either way. I would love to do the double header out West but that's an investment I just can't stomach this year. The Ridge looks incredible though.
