Author Topic: HELP - Stripped flathead insert in 81' VB44A Slide  (Read 549 times)
Offline verro
« on: April 25, 2022, 01:49:11 PM »
Anyone got any advice on getting this out? Already tried rubber-banding it.
Stripped piece
Slide
New piece
1981 CB650
Offline fizzlebottom
Re: HELP - Stripped flathead insert in 81' VB44A Slide
« Reply #1 on: April 25, 2022, 02:45:30 PM »
If you can get a driver to bite at all, soak it in penetrating oil first for several hours. Just let it pool up in there and hope it creeps down into the threads. Maybe try getting some penetrating oil down from the other side too. Make sure its a good oil, like Kroil or acetone/ATF mixture. Don't bother with WD-40.
If you still can't get it out, a small extractor set might get do the job. You just need to make sure you don't drill into the needle itself.
1982 CB650SC Nighthawk
2024 Kawasaki Z900RS
Offline verro
« Reply #2 on: April 25, 2022, 02:50:51 PM »
Ok thanks will try that out. Also drilling into the needle isnt a problem either, I have a whole carb rebuild kit im installing. Of course this happens on the last one  ::) >:(
1981 CB650
« Reply #3 on: April 25, 2022, 03:57:05 PM »
Do what you can to avoid using any aftermarket brass parts: jets, needles, etc. There are widely known issues with a lot of the common kits out there. Use the o-rings, and clean the hell out of your existing jets when possible.
