Author Topic: The Happy-ish Thread. Share your small wins and mixed blessings.  (Read 83668 times)
Re: The Happy-ish Thread. Share your small wins and mixed blessings.
« Reply #1200 on: March 13, 2024, 10:29:45 PM »
Well I dumped the full tank of premix into my stale fuel container for later use in my chainsaw and mower etc (or maybe in the gas tank of my neighbours new VW just to frighten him when it starts smoking….) and filled it with straight 91 RON fuel and fired it up. It smoked a bit when I started it as the carb was still full of premix and the oil pump was also pumping oil into it, but after a few minutes the smoke cleared.
It gets pretty busy around here with 2 schools nearby so I waited until after 4pm before I took it for a short 3 mile ride, and it appears to be running fine. The Club historic permit coordinator sent me the paperwork to sign and express post back to him, so I’ll do that tomorrow at work. (Spilt a cup of coffee into my personal printer last week so not sure if I’ve killed it)
All going well I should have my red plate by the end of next week. That makes me happy. ;D
Online grcamna2
« Reply #1201 on: March 13, 2024, 10:47:14 PM »
Do you think you can cut a 1/2 hour off of your commute time riding the Yamaha ?
« Reply #1202 on: March 14, 2024, 12:01:16 AM »
Probably not Bill, but I won’t have to pay $20 per day for tolls and $8 for parking, hopefully I won’t be using as much fuel either l, and zooming thru the burbs will be more fun than the freeway. I loved riding my first DT250MX to work through the suburbs of Sydney in 80/81, and in Melbourne on first K1 in 82-85, so looking forward to reliving my misspent youth from 40(+) years ago. ;D
Online grcamna2
« Reply #1203 on: March 14, 2024, 12:29:43 AM »
Very well worth the experience;running the DT will give you more places to ride onto to escape the 'cagers'  too. :)
The mind games some of them play.. Plus the texters  >:(
You might consider them the obstacles and the road an obstacle course  :D
« Last Edit: March 14, 2024, 12:32:24 AM by grcamna2 »
« Reply #1204 on: March 14, 2024, 12:26:06 PM »
Thanks Bill, the freeway is scary at 5am, full of idiots driving pickup trucks at warp speed and cutting in and out of lanes like they’re playing a computer game. It’ll be nice to be able to ride in at a more relaxed pace on the DT, and not have to pay $95 per week for tolls, (just paid my toll account, thought it was $20 per day, no, it’s $31.60…..) and another $30 for parking.
I don’t know how often I’ll be riding it in as the cooler weather approaches, but should be a nice change from the freeway, and being that the bike only weighs 50 pounds more than me, will be super easy to ride around long traffic jams, etc. ;D
« Last Edit: March 14, 2024, 01:51:40 PM by Terry in Australia »
Offline BenelliSEI
  • 1969 cb750
« Reply #1205 on: March 14, 2024, 02:10:19 PM »
Do some of you suffer the same level of “local popularity” as me? Whenever anyone on my stretch of country road has a particularly odd mechanical predicament, they always seem to end up darkening my shop door! The women are more devious, they usually present their problems to my wife who invariably responds with; “I know a guy that can help with that”!
The most recent is a lady who fortunately is incredibly pleasant and equally attractive. She and her husband have the “long two hundred” acres behind our place. Our trails are interconnected and we walk there almost every day. They breed Scottish Hyland cattle and graze them in one of our pastures, most summers. Bottom line, I can’t say “NO” when they reach out……
“Mercury” is about 2.5’ tall. From what I can tell, he’s older than me and was originally cast in five major section. Torso, head, arms and legs. Added to that are a few small wings on his head and feet, and whatever he’s holding in one hand. The leg he stands on has a pipe inserted, that slips over a large rod, in a concrete pot, buried in the lady’s front garden.
I’m guessing (heated some shavings and broken bits with a torch) he’s cast of some weird alloy that’s a mix of lead and who knows what. There are slugs of the same material cast into the ends of each joint and he appears to have been “welded” together by pouring molten material over the joints and smearing them into shape. Much the same way plumbers would “wipe” a lead pipe joint, +75 years ago.
Time and weather have been brutal to this lovely piece. Moisture got into the joints and started splitting them apart, when it froze. Last summer, one arm started to droop and them fell off. When my neighbour tried to lift him off his post (he weighs at least 60 lbs.) the head mysteriously popped off too!
He’s been sitting on my centre bench for months and Spring is coming. I’ve tried heating and applying solder, but the material is so old and dried out that it just falls away….. Yesterday I finally got into it. Was able to drill and tap the lead slug in the neck and screw in a 7/16” bolt. Cleaned it all really well. Brewed up a batch of JB Weld, smeared the threads, packed the hole and threaded it in place. Picked up a small bag of “FAST SET-high strength mortar” used for vertical and overhead repairs. Mixed up a fairly dry batch and packed Mercury’s head full of it. Smeared some around the exposed neck base and then jammed his head in place. Wiped and cleaned up what oozed out and hoped for the best!
Went down to the shop this morning and damned if the head isn’t stuck on rock solid! That made me very happyish. Cleaned up the ragged joint and them smoothed in a nice coat of JB Weld around the “seam”. The colour match is excellent and I’ll knock the shine off with some coarse sand paper when it’s all really dry. Tackling the arm the same way. When it’s done, I’ll probably give the whole thing a few coats of a satin finish urethane, so it lasts longer than me…….. All this for a nice bottle of wine, and a clear bench.
Sometimes I wish I was the “village idiot”!
« Last Edit: March 14, 2024, 02:46:25 PM by BenelliSEI »
« Reply #1206 on: March 14, 2024, 02:50:11 PM »
That’s interesting John, Mercury is the Roman God of translation, (the message carrier) and the Royal Australian Signals Corps badge that I wear on my army beret. I’d be interested to know how his statue ended up on your neighbours farm? The statues are usually cast in bronze, and go grey after a few years in the weather.
You’re like me, the local “Go to” guy for any neighbourhood issues from breaking up a fight across the road a few years ago and taking the car keys off one of the combatants who was clearly drunk so he couldn’t drive off and kill himself and his cat. (I loved his big fat orange cat, who used to sneak into our kitchen to steal any leftover cat food from our cats bowls)
Last Monday our neighbour Sue, who I hadn’t seen in years knocked on our door. Her car battery was flat, so asked if I could help. No problem, I have the batteries out of 2 Subaru’s that I recently had towed away to the wrecking yard, so trolleyed one (still recovering from back surgery so no heavy lifting) two doors up to her place to jump start her car. I told her that if after a long-ish drive the battery was still bad  I’d give her the good battery as I don’t have a use for it, but I guess hers charged up fine because I haven’t seen her since. ;D
Online jgger
« Reply #1207 on: March 14, 2024, 03:02:15 PM »
My wife volunteers me for all her quilting/ sewing friends and every time I say yes I do feel a bit like the village idiot. This would include some of the wife's endeavors where I also end up as a participant.
Offline BenelliSEI
  • 1969 cb750
« Reply #1208 on: March 14, 2024, 03:09:37 PM »
Terry.. It’s a lovely piece. My wife worked with our neighbour at a very nice antique shop in Toronto. The owner imported container loads of interesting stuff, from all over Europe. Mercury came in one of those loads. I’ll ask if they remember where exactly. I don’t think it’s bronze. I melted some bits on my steel bench and they ran together just like solder. I have an old reel of real 50/50 and it wouldn’t mix. The material wiped into the joints literally fell away when heated. I wonder if it’s a pewter blend? The darn thing is so heavy that I’ll have to build a temporary jig to hold the arm I place while the mortar sets!
Offline BenelliSEI
  • 1969 cb750
« Reply #1209 on: March 14, 2024, 03:10:25 PM »
This is great, I feel better. I’m in good company!
« Reply #1210 on: March 14, 2024, 03:11:53 PM »
Good point John, could be pewter. ;D
Online jgger
« Reply #1211 on: March 14, 2024, 05:48:24 PM »
I'm afraid that you may be Scrapping the bottom of the barrel if you are counting me as "good company" there John! At the very least we may both belong in the village idiot classification,  but I have always considered you to be above that!😁
Online grcamna2
« Reply #1212 on: March 14, 2024, 06:40:21 PM »
John,does it have any identifying marks or artist name on it;who made it ?
I'd sure like to know the history.
Offline BenelliSEI
  • 1969 cb750
« Reply #1213 on: March 14, 2024, 08:37:56 PM »
Bill…. Good question! Not that I have noticed but I’ll have a closer look next time.
Offline newday777
« Reply #1214 on: March 14, 2024, 08:50:49 PM »
Well my Busso pipes finally got delivered today but I won't see them until Sunday/Monday as I'm 2500 miles away, spending time with the grand kids.
Stu
My current rides
Prior bikes....
Offline BenelliSEI
  • 1969 cb750
« Reply #1215 on: March 14, 2024, 08:56:02 PM »
[/Pewter (/ˈpjuːtər/) is a malleable metal alloy consisting of tin (85–99%), antimony (approximately 5–10%), copper (2%), bismuth, and sometimes silver.[1] Historically, pewter was an alloy of tin and lead, but most modern pewter does not use lead in order to avoid lead poisoning. Pewter has a low melting point, around 170–230 °C (338–446 °F), depending on the exact mixture of metals.[2][3] The word pewter is probably a variation of the word spelter, a term for zinc alloys (originally a colloquial name for zinc).[4]
Terry…… After reading this,I think it might be.
Offline BenelliSEI
  • 1969 cb750
« Reply #1216 on: March 14, 2024, 08:56:54 PM »
Congrats! Finally.
Online Don R
« Reply #1217 on: March 14, 2024, 10:06:52 PM »
  I had a left-over car show sweatshirt, it was too small for me or my wife so I sat it in the cedar chest to wait until it fit someone. A couple weeks ago I gave it to my oldest granddaughter who is 12 and loves my car clubs shirts.
 Tonight, my daughter texted that Olivia said she loves that sweatshirt, every time she puts it on it's like getting a big hug from Papa. Excuse me, I got something in my eye.
Online jgger
« Reply #1218 on: March 14, 2024, 11:20:11 PM »
That's awsome Don. When my boy was about 10 or 12, I think, he found my old riding jersey from my desert racing days. You couldn't pry it away from him with a crow bar.
What you have in your eye is a great memory leaking out, you need to seal that up with a real hug!
Offline BenelliSEI
  • 1969 cb750
« Reply #1219 on: March 15, 2024, 10:58:53 AM »
Arm surgery went well on “Mercury” today. Stuffed the elbow with a sheet of paper towel and then filled the bicep with the High Strength Quick Set Mortar.  Wiped away what oozed out and looks good. Will seal the seam with a thin layer of JB Weld next. Accumulating massive Brownie Points on this one! Very Happyish.
« Last Edit: March 15, 2024, 11:03:47 AM by BenelliSEI »
Offline newday777
« Reply #1220 on: March 15, 2024, 12:19:53 PM »
Ah you cuffed Merc with zip ties eh John?
Stu
My current rides
Prior bikes....
Online grcamna2
« Reply #1221 on: March 15, 2024, 03:13:57 PM »
Merc-cruiser  ;D is coming together nice and will be ready to spend more time sitting in the garden patch  :D
Offline BenelliSEI
  • 1969 cb750
« Reply #1222 on: March 15, 2024, 04:10:26 PM »
His arm actually was floating, a few mm off his thigh. With all the mortar I packed into it the slight gap is negligible and that touch point may prevent future “sag”! This project had me baffled, but finally making good progress.
You can see where I started knocking down the high spots in the JBW around his neck. Takes the gloss off and it will blend quite nicely.
« Last Edit: March 15, 2024, 04:14:42 PM by BenelliSEI »
Online Don R
« Reply #1223 on: March 15, 2024, 11:44:58 PM »
 You think he looked bad you ought to see the other statue!  Seriously though, that's some awesome restoration work.
Online jgger
« Reply #1224 on: March 16, 2024, 01:20:20 AM »
^^^ now that's funny!
Like when I caught my garden gnomes bar- b- queing My neighbors pink flamingos. They were having a good ol' time!
« Last Edit: March 16, 2024, 01:24:04 AM by jgger »
