Author Topic: Carburetor rebuild parts  (Read 1278 times)
Offline ebrown0104
« on: April 30, 2022, 03:50:08 PM »
I’m getting leaks from the fuel interconnect tubes (number 3 in the diagram). I’m also going to replace the accel pump hoses while I have it apart (number 8 ). I was hoping someone would have the correct sizes for the o-rings and tubing I need without having to tear them apart. Thank you for any help
Re: Carburetor rebuild parts
« Reply #1 on: April 30, 2022, 07:37:57 PM »
I use the kits #48-1995 from PartsNmore.com, which fit all the PD carbs found on the 750K/A bikes.
This is JUST THE RUBBER parts and a new float valve (yours have age-hardened tips by now, if OEM) for the floats. Re-use your old brass, as none of the kits currently available for these carbs today have correct metering brass.
