Author Topic: Alternative CB350F Headlight Bucket  (Read 711 times)
Offline Bristledisk
« on: May 01, 2022, 06:49:19 AM »
Hi All, I've been searching for a headlight bucket for my 1973 CB350F. CMNLS list that the bucket was used on 21 different models but I can't seem to find one. Any suggestions on an alternative/similar fit bucket e.g. how different is the CB400F bucket?
1977 CB400F, 1976 CB750F1, 1974 CB550K, 1975 CB550K, 1976 CB550K2, 1973 CB350F
Offline Flyin900
Re: Alternative CB350F Headlight Bucket
« Reply #1 on: May 01, 2022, 09:13:42 AM »
I have a couple of CB400F buckets in good shape. One with front chrome headlight lens trim ring. There are some differences, yet I can't say what specifically they are on the CB400F vs CB350F.
Based in Ontario if you find that the 400F will work for you and are interested send me a PM.
« Last Edit: May 01, 2022, 09:30:10 AM by Flyin900 »
1978 CB550K - Super Sport
1982 CM450A - Hondamatic
1982 CB900C - Custom
1983 CX650E - Eurosport
Offline Bristledisk
« Reply #2 on: May 01, 2022, 11:05:22 AM »
Thanks for the reply. I actually own a restored 400f. I shall try temporarily fitting the 400f headlight to the 350f. It’s difficult to see the differences between the 2 models from pictures.
Offline Flyin900
« Reply #3 on: May 01, 2022, 11:26:51 AM »
I looked at the bucket as I too own a number of these bikes. My take is the 400 bucket design likely has less room for wiring given the small back pocket in the shell. The CB350F has a more rounded off shell design. I think both will bolt up to the fork ears or bracket in the 400 set up.
Offline grcamna2
« Reply #4 on: May 01, 2022, 12:42:40 PM »
I found that you can use the headlight bucket from a Honda CB350K4-K5/G model twin cylinder;that's the same one.  ;)
