Author Topic: Whats Up With This CB550 Rotor I Found?  (Read 663 times)
Offline geoluv
  • Brooklyn, NY
« on: May 03, 2022, 07:04:05 PM »
I'm looking to do the dual rotor upgrade to my cb550k1.  Found this rotor that is marked as a "cb500/cb550" rotor.  Looks identical to every cb550 rotor I've seen but it has notches and a slight lip on the back, presumably for the speedo drive.  I'm thinking this rotor is actually from some other cb model, gullwing perhaps?  If it is indeed for CB550 and I buy this rotor will that save me the trouble of modifying my speedo drive or is there still not enough clearance between the shoulder of the hub and the inner diameter of the rotor?
« Last Edit: May 03, 2022, 07:06:25 PM by geoluv »
1975 CB550K1 Candy Jade Green
1977 CB550F2 Candy Presto Red
Countless vintage bicycles
Re: Whats Up With This CB550 Rotor I Found?
« Reply #1 on: May 03, 2022, 08:18:12 PM »
That has been machined so you can use the standard speedo drive plate, makes your conversion a pices of pee
Offline Shtonecb500
    • Youtube profile
« Reply #2 on: May 03, 2022, 09:40:24 PM »
that should do the trick
Thats the notch you make in the back so the stock speedo drive fits. I made the same notch in the back of my 750 dual disc.
« Last Edit: May 04, 2022, 08:28:38 AM by Shtonecb500 »
73/74'' CB500/550 resto-mod - sold
75' 750f 91' cbr f2 swap cafe - mock up
74' 750 chopper hardtail - complete - sold
74' CB750/836kit - Black mix & match - daily rider - always tweaking
71' cb500 K0 survivor - complete
71' K1 - CANDY GOLD/BROWN Winton kit - in process
Offline flatlander
« Reply #3 on: May 03, 2022, 10:53:56 PM »
indeed, someone else already used it as a second rotor. get it quick!
Online Don R
« Reply #4 on: May 04, 2022, 09:23:24 PM »
  A lucky find.
