Author Topic: Searching for Carb o-rings - Fuel Passages  (Read 722 times)
Offline boatsdickson
  • 1978 836 K8
« on: May 08, 2022, 07:51:36 AM »
While I continue to search the forum I'll also ask the others.
I'm redoing my PD42B's on a 78 750 and realized that my supply of fuel passage o-rings are MIA. The Honda fische calls them a "Joint Set, Fuel" with a part # of 16026-393-004, #3 on the diagram. These are the metal tubes that connect the carb bodies to the others that have and o-ring on each end. I'm searching for the 6 o-rings but not the metal connecting tubes. Anyone care to chime in with a place to order them or maybe a size of the o-rings? I've attached the Service Honda exploded diagram to this thread.
I'll continue searching the forum and the "Where can I buy parts" thread.
Thanx all....Boats
« Last Edit: May 08, 2022, 07:54:33 AM by boatsdickson »
"No. We're all our own prisons, we are each all our own wardens and we do our own time. I can't judge anyone else. What other people do is not really my affair unless they approach me with it. Prison's in your mind. Can't you see I'm free"?  Testimonial of Charles Manson
  • 1978 836 K8
Re: Searching for Carb o-rings - Fuel Passages
« Reply #2 on: May 08, 2022, 11:35:59 AM »
Thank you
