Author Topic: Front and Rear Wheel Conversion  (Read 415 times)
Offline Ellz10
  • ZZ
  • Knowledge is Power
« on: May 09, 2022, 04:06:43 PM »
So I'm on the hunt for front end forks. I'm already planning on snagging the triple tree that Joker Machine has on their site so I won't have to worry about clearance issues. I'll probably end up grabbing CBR's 600 or 1k's for the front forks, doesn't matter to me. My confusion in this entire matter and my question is this: how am I to go about finding a set of matching wheels for the front and rear if im sticking with the drum setup in the rear?
Do they make hubs that you can buy and just swap them out for a particular set of wheels you want?
Thankful for everyone on this forum. Grateful to continue to learn so much.
'77 K7 - http://forums.sohc4.net/index.php/topic,193043.msg2251436/topicseen.html#new
Offline calj737
  • I refuse...
Re: Front and Rear Wheel Conversion
« Reply #1 on: May 09, 2022, 04:40:42 PM »
The Joker triples are setup for the 750 with stock 35mm tubes. Be aware of that before you opt for non-stock forks.
You can use the stock hubs and simply lace them to aftermarket spoked rims. Or are you trying to go for a mag-type wheel?
Offline tourmax
« Reply #2 on: May 09, 2022, 05:59:33 PM »
I grabbed a front and rear suspension from an RZV500 and am adapting R6 front and rear wheels. Can be seen here:  http://forums.sohc4.net/index.php/topic,189755.0.html
Not sure how you are going to deal with a rear drum brake if you want modern wheels though.
Maybe get some custom spokers built for you? you can probably spec what type of hub and brakes you want, but probably won't be an "inexpensive" solution....
1989 FJ1200, 1983 Yamaha Venture (Vmax conversion), 1985 VF 750F Interceptor, 1982 CB650SC, 1988 Corvette convertible (Z52), 1983 Mustang GT, 2009 Mini Cooper Clubman.Couple more lying around but this is long enough already!
Offline Ellz10
  • ZZ
« Reply #3 on: May 09, 2022, 06:53:58 PM »
I thought about that as I was reading this. I wanted to stick with the drum, but now I'll probably end up opting for the disc brake conversion - more options.
I didn't realize that til now unfortunately. So let's say I go with the Joker triples, and refurbish my stock 35mm 750 forks - now I'm still stuck with figuring out how to adapt a new wheel to the front end (rear shouldn't be a problem if I go with the disc conversion).
I don't want to have mismatched rims.
Offline calj737
  • I refuse...
« Reply #4 on: May 09, 2022, 08:56:48 PM »
No, you’re not stuck. You can use a Cognito front hub conversion though they are mostly for USD modern forks, that rules out the Joker triples. You can also use an old HD front hub, laced to a new rim that accepts discs. There’s some other spacers and caliper brackets to fabricate, but…
I have a 550 that I bought Joker triples for, but had to shorten the stem as it’s 0.780 too long for the 550. I bought new Forks by Frank tubes and used my stock hubs, upgraded rims and spokes. Single stock disc. It’s ok, but nowhere as nice as modern forks and brakes. All depends on how you intend to ride and use the bike whether the investment is worth it. For a stock street bike, used occasionally, I’d stick with stock setup, better tires and pads, and just get nicer rims (Sun by Buchanan’s). There’s later model 750s that had dual discs and a disc out back too, so you have some stock options and can still run the Joker triples.
