Author Topic: installing K0 side cover screens?  (Read 797 times)
Offline Magpie
« on: May 10, 2022, 01:49:01 pm »
I am thinking of using a bit of epoxy at  each corner of the screen to attach it to the back of the side cover, does anyone have better a way to do this just so I don't screw this up? I've put a couple of deep sockets on the screen to hold it flush to the cover. Thanks, Cliff.
Offline MauiK3
  • A K3 is saved
  • Old guy
Re: installing K0 side cover screens?
« Reply #1 on: May 10, 2022, 02:52:07 pm »
How are they originally attached I wonder?
1973 CB 750 K3
10/72 build Z1 Kawasaki
« Reply #2 on: May 10, 2022, 03:35:28 pm »
  They were glued. I don't have any that weren't removed for paint or I'd get a pic. I made a set of screens out of a desk file holder from Staples once.
 I think they had a dab of glue near each tab. My google pics don't show one, I'll take one off and have a look.
« Last Edit: May 10, 2022, 04:31:59 pm by Don R »
« Reply #3 on: May 10, 2022, 03:55:47 pm »
 Not original glue. The silver one is the file holder material, it's painted black on the front side. I've had original and NOS and while they were quite similar I'm sure the glue was different. Neither painter listened to me about painting the back edge and letting the overspray show on the inside.
« Last Edit: May 10, 2022, 04:34:33 pm by Don R »
Offline Magpie
« Reply #4 on: May 10, 2022, 08:58:28 pm »
i think the tabs on the inside held them in place on the original covers. On the Yamiya repops the tabs are more for positioning I would say.
« Reply #5 on: May 10, 2022, 09:03:16 pm »
  Mine all had some sort of glue, the red one pictured is real honda but has been painted. I was thinking the blue green were real but remembered they are not.
« Last Edit: May 10, 2022, 09:13:50 pm by Don R »
Offline 71 V12
« Reply #6 on: May 11, 2022, 01:45:51 pm »
I recall reading somewhere that on new covers the tabs need to be softened with soldering iron and then bent onto the mesh to hold it. Never tried it but it sounds plausible.
Offline WideAWAKE
« Reply #7 on: May 11, 2022, 03:23:52 pm »
From Yamiya - see attached photo
Also, anyone got an easy source for screen??
Offline Magpie
« Reply #8 on: May 11, 2022, 06:05:19 pm »
Thanks for that. Looks like you have to very careful not to distort the cover.
Cliff.
« Last Edit: May 11, 2022, 06:11:26 pm by Don R »
Offline atm cycles
« Reply #10 on: May 12, 2022, 07:56:00 pm »
The tabs are heated gently and bent over
Offline Magpie
« Reply #11 on: May 14, 2022, 10:34:14 am »
Thanks wideAWAKE. I used a soidering iron with a 90 degree bend in it, held my breath as I was afraid what the heat might do to the front side. I only did 4 tabs and didn't hear them quite enough but they are holding the screens.
Offline WideAWAKE
« Reply #12 on: May 14, 2022, 10:54:36 am »
Looks good!! Seems 4 tabs is plenty to hold it in place.
I will be doing mine this week some time.
I think your 90deg tip is a good idea.
I’ll go dig mine out.
