I am doing a cleaning on a set of #627 CB500 carbs that a friend recently acquired on the bike with a POD filter set and an aftermarket exhaust.
He is putting a stock air box back on the bike and possibly keeping the aftermarket exhaust.
The stock main jet is supposed to be a #100 size and the Keihin jet in there now is a larger #105 size. The correct stock needle clip position is 3 down from the top. The current position is 4 down from the top, so a richer setting along with the larger main jet.
The slow speed jet is a #40 which is the correct stock size, so no changes made there.
The question is take the needle clip back to the #3 stock setting with the stock air box or move it one notch higher to the #2 position to compensate for the larger #105 main jet vs the stock #100.
He will not be interested in farting around with different needle settings on these carbs to try and dial this in after my work is done.
So what are the thoughts from members who are knowledgeable on carbs in general, with some real world experience please.
