Author Topic: '70 K0 Throttle Twist Force  (Read 598 times)
Offline Scootch
  • Someday I'll know what I needed to know years ago
« on: May 11, 2022, 06:09:03 AM »
This has probably been covered previously. I did a search but...
Is there a way to reduce the amount of force required?
Change to a fatter grip. Probably replace the springs in the carbs. If so what springs?
Anything else?  TIA
« Last Edit: May 11, 2022, 06:31:43 AM by Scootch »
Offline Deltarider
Re: '70 K0 Throttle Twist Force
« Reply #1 on: May 11, 2022, 07:35:25 AM »
Dunno if this may apply to your K0 model, but me thinks this is simple and effective: http://www.sohc.co.uk/index.php/topic,26115.msg239571.html#msg239571
CB500K2-ED Excel black
Offline Prospect
« Reply #2 on: May 11, 2022, 05:29:04 PM »
Link only works if you're a member (attached picture).  I'd be interested to know as well.
Current Bikes
1969 CB750  Sandcast #256
1971 CB750K1
1972 CB750K1
1975 CB400F
1975 GL1000 Goldwing
1954 Harley Davidson Panhead
1957 Harley Davidson Panhead
Toronto Canada
Offline 69cb750
« Reply #3 on: May 11, 2022, 05:39:42 PM »
Kaw Z1 grips are better.
I have received two where carb springs were cut shorter.
Offline Scootch
« Reply #4 on: May 11, 2022, 05:44:10 PM »
I'm not sure what the link is supposed to show? I don't see a picture or any info
Offline Prospect
« Reply #5 on: May 11, 2022, 06:05:28 PM »
There is a picture attached that can only be viewed if you are a member or the UK forum.  I'm not a member so I ( and presumably you) can't see it because we're not members.  I'd assume the attached picture would be self explanatory.
Current Bikes
1971 CB750K1
1972 CB750K1
1975 CB400F
Toronto Canada
Offline Prospect
« Reply #6 on: May 11, 2022, 06:08:52 PM »
I use this thing.  It work well for long rides and eases the strain on the arm.
Current Bikes
1971 CB750K1
1972 CB750K1
1975 CB400F
Toronto Canada
Offline Scootch
« Reply #7 on: May 11, 2022, 07:21:15 PM »
Thank you for the information. That is something that I didn't know existed. I would still like to pursue the root of the problem and see what could be done with the carb springs...
« Reply #8 on: May 11, 2022, 07:25:45 PM »
 You may need to polish the slides and clean the bores. Mine don't turn hard so it could be cable routing or condition also, the problem in making it easier to turn is the 4 cable carbs have no manual return.
Offline Deltarider
« Reply #9 on: May 11, 2022, 11:38:33 PM »
Here it is.
Offline Scootch
« Reply #10 on: May 12, 2022, 02:53:29 AM »
Here it is.
Thanks for the info. That is a good idea. Unfortunately K0 carbs don't use that setup...
Offline Ujeni
« Reply #11 on: May 13, 2022, 10:20:17 AM »
If everything is in proper working order, it should not take too much force to twist the accelerator. I suspect you have one or more of the following:
  • Grime between the plastic throttle sleeve and the handlebar. Clean and lubricate.
  • Dirty, unlubricated or damaged throttle cable. Inspect and lubricate or replace. Also worth making sure that your throttle cable routing is correct.
  • Dirty slides and carb slide chambers. Inspect and clean.
Ujeni Motors
Sandcast #410
Sandcast #538 Watch the restoration!
Sandcast #6592 All original daily driver.
Offline Scootch
« Reply #12 on: May 13, 2022, 12:16:27 PM »
Thank you for the suggestions 👍
