Author Topic: Power Arc CD2 Ignition CB750 K6  (Read 894 times)
Offline HughL
« on: May 15, 2022, 11:52:50 AM »
Hello,
I recently purchased a cb750 k6 and found it has a power arc IDS. I am unsure how to set my timing with it if I need to since I can't find TDC as the old markings and plates are removed in place of this new ignition. Anything helps. Thanks.
Offline Old Scrambler
Re: Power Arc CD2 Ignition CB750 K6
« Reply #1 on: May 15, 2022, 12:35:32 PM »
You will likely need a TDC piston-stop tool and a conversation with another user.
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
« Reply #2 on: May 15, 2022, 09:13:47 PM »
Did the seller include the stock parts, especially the advancer? It has the Top dead center mark. You are supposed to rotate the motor to the T mark, then remove the advancer and install the Power Arc parts and rotate the wheel until the led lights up. If you don't have the stock advancer, then you will have to resort to other means to find TDC. The seller of the PA once recommended using a soda straw through the spark plug hole when a member here got stranded on the road. There is No way to check the PA timing dynamically with a timing light.
Now, be warned, the Power Arc system is discontinued due to it's lack of reliability, and there is no support for them. I wouldn't trust one any further than I would be willing to push my bike unless I had towing insurance, especially if it's hot; the member I mentioned had two of them fail, and both times it was in the Arizona heat.
Offline Nicklopic
  • New York
« Reply #3 on: May 15, 2022, 09:43:55 PM »
There’s a seller on eBay that makes a really nice TDC indicator. It’s convenient as heck with that stupid thing.
On a side note, that ignition is HOT GARBAGE. I have one on my 650. Died on me in fall coming to a light at a bad intersection despite having a vented timing cover. Made me miss class (Cut holes on the forward and rear sides to flow air over it)
The multispark gave me like a soft limiter that struggled to build revs over 7k under load.
I really liked the possibilities with it. The features are cool, the possibilities of setting up a quick shifter, retarding timing with boost or load or something. I even made my own rotary switch to flip maps on the fly.
I would advise you to get rid of that thing. If you’re really into keeping it, I have the cable to tune it and that rotary switch since I’m getting rid of it.
https://www.ebay.com/itm/383422171079
80' CB650
Build Thread
Offline HughL
« Reply #4 on: May 16, 2022, 06:39:53 AM »
I guess I'll start looking at a dyna ignition then.
Offline HughL
« Reply #5 on: June 10, 2022, 08:42:30 AM »
I did some more research and plan on keeping it until it leaves me stranded. It does have a TDC indicator LED on the module itself, but other than that I'm not really sure how I'm supposed to set valve clearances and adjust my timing chain properly since I only have TDC to work with, and I imagine it's the TDC of 1-4. Thanks.
Offline slikwilli420
  • Master of Disaster
« Reply #6 on: June 10, 2022, 08:52:22 AM »
Just figure out how many degrees past TDC to rotate for valves and chain adjustment (I think its 15 per Hondaman) and set up a small sharpie mark on your case inside the ignition cover. Rotate to TDC then to that mark, check 4 of the 8 valves and cam chain, then rotate again to that spot and check the other 4 valves and finish the cam chain tension adjustment.
