Author Topic: turn signal/running light CB 750 1974  (Read 402 times)
Offline muzzy
« on: May 20, 2022, 02:57:27 PM »
Do the front mounted running lights remain on even when not being used as turn signals
Regards Murray
Offline MauiK3
  • A K3 is saved
  • Old guy
Re: turn signal/running light CB 750 1974
« Reply #1 on: May 20, 2022, 03:01:57 PM »
Not that I’ve ever seen.
1973 CB 750 K3
10/72 build Z1 Kawasaki
Offline newday777
« Reply #2 on: May 21, 2022, 02:43:05 AM »
Regards Murray
If your turn signals have 2 wires plus the ground on the front yes there should be running lights on with the headlight switch in the on position on the 74 cb750. It is possible someone changed the turn signal assembly to a 1 wire on your bike as the rear turn assembly is, and thus no running lights in there on your bike. How many wires does your have muzzy?
Stu
My current rides
Prior bikes....
Offline muzzy
« Reply #3 on: May 21, 2022, 01:52:14 PM »
Thanks for the reply I will check to-day feel like I have covid so still resting
Offline BenelliSEI
  • 1969 cb750
« Reply #4 on: May 21, 2022, 02:02:47 PM »
My K4 has been wired that way. The lamp sockets are the dual filament style and are on with all lights. The turn signals are tied to the brighter circuit. Works well.
Offline muzzy
« Reply #5 on: May 21, 2022, 02:30:51 PM »
Thanks to all I have 2 wires running to the side lamps, so assume its quite normal for side lamps to be on with the headlight.
« Reply #6 on: May 21, 2022, 09:41:05 PM »
 We used to add the running lamps to bikes that didn't have them. My brother is also fond of the red rear turn signals/running light lenses.
