Author Topic: Oil Pressure cb750  (Read 10330 times)
eschopper
Oil Pressure cb750
« on: March 05, 2007, 12:43:01 PM »
I recently acquired a 1972 cb750k.
I was wondering what the normal oil pressure for this engine is?  Also, I was wondering if I needed to purchase another oil pump?
My oil pressure gauge is brand new from drag specialties and I do not have an oil pressure light, tachometer, or speedometer.  The bike has been converted into a chopper.
Usually, when I start the bike up the oil pressure is between 40 to 60 psi.  Sometimes the needle will jump around from 0 to 60 psi.
As the motor warms up it drops down to around 15 to 20 psi.
While riding the pressure is around 20 to 40 psi.
At stoplights the pressure can dip to around 5 to 12 psi.  If it goes below this the bike will stall out.
I am new to this type of engine and I greatly appreciate any help on this matter.
Offline Bob Wessner
  • "Carbs Suck!"
Re: Oil Pressure cb750
« Reply #1 on: March 05, 2007, 01:18:40 PM »
I'm not sure where you live, but the ambient air temp can have a lot to do with the start-up oil pressure. I live in Michigan and on a summer morning start with the temp. around 50F, and standard 10w40 oil, the pressure can jump to almost 80 lbs. Once the engine is hot and I'm riding, it seems to register 10 lbs per 1,000 r.p.m. on the pressure gauge. I have to admit I don't know what the optimal specs are, but this seems to be fine.
johnny-from-bel
« Reply #2 on: March 05, 2007, 01:21:57 PM »
10 lbs per 1,000 r.p.m. is the rule of thumb on most engines. The shop manual states 7.1 PSI as abolute minimum.
« Reply #3 on: March 05, 2007, 01:32:47 PM »
Oil pressure at speed (~60mph = 60 - 80psi). As mentioned by Bob on hot days pressure will be less and can drop to around 50psi. At idle should still be around 60psi (when I start up my K2 or K4 pressure goes up to 60+psi and stays there. Id check your gauge.
cheers
Andy
Offline lrutt
« Reply #4 on: March 05, 2007, 01:51:22 PM »
my 76 with 28k miles will register 80+psi first start and will not drop below 50 psi even warm at idle. That is my only comparison point. I should move my gauge to my 78 and see what it runs.
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #5 on: March 05, 2007, 02:36:33 PM »
Andy,
So what you are saying is when hot, if you pull up to a stop and idle, say around 900-1,000 r.p.m. you still show 50 psi on the pressure gauge?? Mine will drop to about 10 lbs and it's been that way since the mid-70's.
« Reply #6 on: March 05, 2007, 02:59:27 PM »
Ah good question Bob and I dont know as I dont recall the idle oil pressure when its hot - 85F+ (only when running on the highway/roads Ive looked down and sometimes have seen my psi lower than usual - like 50psi - and this is when its hot or riding through deserts etc - I cant say for idling in deserts). I was talking about idle oil pressure at regular temps - like 50 -65F (upon start up and then check oil pressure).
sorry for any confusion,
cheers
Andy
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #7 on: March 05, 2007, 03:31:16 PM »
No problem, just wanted to make sure as to whether or not I had an issue.
« Reply #8 on: March 05, 2007, 03:40:37 PM »
Bob,
If you have been riding since the 70s like that then no I dont think you have an issue  ;)
Issue is all mine,
cheers
Andy
Offline Dave K
« Reply #9 on: March 05, 2007, 05:14:15 PM »
Bob, I have had an oil pressure guage on since new. It reads what yours does at both idle and highway speeds. I can't even say I have seen any change in oil pressures since it was new.
Offline Hockers Choppers
  • go away winter!!!
« Reply #10 on: March 05, 2007, 05:29:33 PM »
cheers
Andy
Andy, you need to check YOUR gauge!!
The thing about common sense is that, it's not that common.
1978 CB750F SUPERSPORT 850cc, cam, porting, dyna ign, cr29's lotsa elbow grease and $$'s. Worth ever penny!!  (S0ld)
05 VTX1800F darkside
cb750 k1
eschopper
« Reply #11 on: March 05, 2007, 05:46:39 PM »
Thanks for all of the replies, all of your help is appreciated.  It helps me to figure out if my oil pressure is average or not.  Nobody around here has anything close to what I have, so this forum really helps me out!
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #12 on: March 05, 2007, 07:10:34 PM »
How sure are you about the gauges accuracy? Does the oil pressure light ever come on at idle? Granted, it too might be off, particularly after all these years, but theoretically the threshold for the light is +/- 7 lbs.
Offline mrbreeze
  • Not your average
« Reply #13 on: March 05, 2007, 09:45:34 PM »
My gauge goes considerably lower at a warmed up idle. Once revving down the road,it comes back up. As far as I am concerned...this is normal.I've never seen one anywhere neer 50 lbs. at a warmed up idle. Some of you here may have a whacked out gauge but I'll say one thing.........You'll know real soon if you have a lack of oil pressure!!!
MEMBER # 257
Offline chung
  • Giddy Up
    • chungfucycles.com
« Reply #14 on: March 05, 2007, 10:42:49 PM »
I thought I replied to this???
Pressure is an indication to a resistance of flow. It is not an indication of flow. They call it an idiot light for a reason but likewise, the number on the gauge is just a number..... a reference point.
Pull a lash cap when the motor is smokin hot. The gauge may say 0 PSI but it can blister an eyeball from all the oil slinging about. Wear glasses boys and girls.
I have seen the oil light blinking so much @ idle on the 750s that I seized an engine once because I ignored the IDIOT LIGHT. (Rag in the tank) The oiling Syst on these bikes is NASA quality stuff. Pull the pump and measure it to spec if you are that scared or unplug the bulb.
It was normal for me to be riding with an ambient of 110F in the shade @ 5pm. That has gotta be 150 plus on the road, I have almost fallen off the bike from the heat. Almost 300 miles round trip EVERY DAY for 3 years. I ain't making this #$%* up. I typically used HONDA GN4 10w40 but CASTROL GTX is a fine oil as well, 20/50 or 10/40. The light only annoyed me, If it keeps going then it's all good right? Parts are parts. we break them and we replace them. (except for my lungs and liver)
I guess the point is that if you have oil flinging out of the lash caps on BOTH sides of the motor then it will probably live longer that you will. With a little maintenance?
Member#2815
1971/76 CB750 Hack @970cc,
1975 CG750K
1970 CB350,
1972 YDS7, 250
1972 YR5, 350
1977 RD400,
1978 Piaggio Grande/Batavas HS50 Special
1981 XS650 Special II
