Author Topic: Removing Top Bolt on Front Fork problem  (Read 632 times)
Offline Bristledisk
« on: May 26, 2022, 12:35:20 PM »
Hi All,
I'm attempting to remove the top front fork bolt (see image). I unscrew it nearly to the top then the thread clicks and seemingly drops back a few threads again. I suspect the thread is damaged or am I missing something. Any ideas on how I can get this bolt out? It's a 350F. Thanks in advance.
1977 CB400F, 1976 CB750F1, 1974 CB550K, 1975 CB550K, 1976 CB550K2, 1973 CB350F
Offline calj737
  • I refuse...
Re: Removing Top Bolt on Front Fork problem
« Reply #1 on: May 26, 2022, 12:38:24 PM »
For starters, that cap is under serious tension from the internal spring (assuming you haven’t released that via the damper rod at the bottom?). Press down on it while you unscrew it. You should also lightly loosen the fork tube clamp. If you still can’t get it to release, going to need to remove the entire fork leg from the triple trees and take other measures for complete disassembly.
« Reply #2 on: May 26, 2022, 12:47:39 PM »
 Wow that's odd, pry or lift under the edge while being ready for it to shoot off?
« Reply #3 on: May 26, 2022, 05:03:49 PM »
If its like the 450/500 and you have it on the centre stand with front in air there is a threaded rod connecting the top nut to the damper at the bottom, you need to push the slider up and you will see a locknut
« Reply #4 on: May 26, 2022, 08:02:26 PM »
Yes what model of bike ? 750's they just pop off unless the oring is holding them and yours isn't having that problem. That little gauge does looks like a 500 maybe.
Offline Bristledisk
« Reply #5 on: May 26, 2022, 08:18:43 PM »
It’s a 1973 CB350f.
Offline Shtonecb500
    • Youtube profile
« Reply #6 on: May 26, 2022, 08:42:50 PM »
use an impact drill, apply pressure to the nut to work against the pressure of the spring inside. You are going to have to apply pressure when reinstalling....when that nut comes off your spring is going t want to shoot out and your front end is going to want to drop if you work on both forks at the time time.
apply pressure when removing and installing.
73/74'' CB500/550 resto-mod - sold
75' 750f 91' cbr f2 swap cafe - mock up
74' 750 chopper hardtail - complete - sold
74' CB750/836kit - Black mix & match - daily rider - always tweaking
71' cb500 K0 survivor - complete
71' K1 - CANDY GOLD/BROWN Winton kit - in process
Offline Little_Phil
« Reply #7 on: May 27, 2022, 04:01:28 AM »
+1 on this.  Makes adding fork oil a pain.
Offline Shtonecb500
    • Youtube profile
« Reply #8 on: May 27, 2022, 06:23:35 AM »
man, i havent replaced fluid with fork still installed in a long time.
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #9 on: May 27, 2022, 08:17:56 AM »
Need a shop manual.
1973 CB 750 K3
10/72 build Z1 Kawasaki
Offline Shtonecb500
    • Youtube profile
« Reply #10 on: May 27, 2022, 12:31:32 PM »
Was looking through mine
Offline Quattrocilindri
« Reply #11 on: May 27, 2022, 01:05:08 PM »
Not difficult at all if you use a small funnel or a syringe attached to a flexible hose and you have the 105 cc of ATF measured in a cup ready to pour. If the bike  is on the side stand with the upper fork cap undone and  2-3 spring coils exposed, you have the space to do it with minimal mess.
Just insert the flexile hose between the spring coils and pour the fluid. Then place the bike on the center stand; the exposed spring will drop into the fork tube and the cap threads can be engaged and the cap .can be fully installed.
Repeat the same operation for the other fork. This is how I have changed the fluid on my 350F.
However, if the OP wants to fully dismantle the fork, then it is easier to do fully remove the legs and do that in a bench vise.
