Author Topic: Leaving at dawn to pick one up...  (Read 3444 times)
Offline britman
Re: Leaving at dawn to pick one up...
« Reply #25 on: June 05, 2022, 05:46:37 AM »
19k on the clock...
Offline spotty
« Reply #26 on: June 05, 2022, 05:21:09 PM »
Last trip to pick up bikes was a two day trip. came back with these:
can't see it, but there's an FJ1200 on the other side of the Venture:
The interceptor wasn't part of the purchase that day. I've had that since the mid 90's.
nice venture, i just got a 99 model, the harley clone one, its got a ways to go before it hits the road, its amazing how much of it is just dress up crap , the engine is the same as yours but there are 8 cast alloy covers over the barrels and heads/rocker covers just so it looks air cooled and don't get me started on the engine breather pollution cr4p, that's all going in the bin. it might even get vmax carbs and cams with a  less restrictive air box, noisy exhaust can't hurt either
well, the Royal Star Ventures use the same base engine architecture, but there's not much the same in them.
Cams, carbs heads, etc are all different and are aimed at making more low end torque at the cost of higher rpm horsepower. Transmission and final drive are also different. You can fit a RSV transmission in gen1/2 cases (I have one in mine) but the gearing is very high (intended for loafing along at lower rpms). I ended up swapping in a gen1 Vmax final drive, which, combined with the RSV gearing gives me digger lower gears until 3rd and then deep overdrives in 5th and 6th. It also eliminated the gen1 issue with soft thrust washers in the geartrain and the shift sector pins dropping out of the gen1 stamped steel retainer (RSV uses a machined from billet retainer that has bores to hold the pins instead of a bent metal tab).
You can toss in VMax cams, but without the heads it's not a big jump. Not to mention the vmax cams are made to spin rpm to make power, which the RSV is not designed for. Even with Vmax cams and heads, the RSV carbs will choke it down to where you don't see a lot of gain in the parts swap. Your "ass-o-meter" may say it's more, but the dyno reveals it to be not as much as it feels.
Nearly all the power in the XVZ/VMX engines is in the heads. Port size, angles, valve sizes, etc. Without the heads, adding other VMax parts just means they're "hobbled" like the RSV engines.
VMax carbs are essentially the same as Gen 1/2 Venture carbs. The RSV got smaller venturis, again, to make better lower rpm torque numbers at the expense of HP numbers. The real difference between gen1 Vmax carbs and gen 1/2 Venture engines (other than jetting) is the vboost system. No way to make that work on a RSV, unless you want to spend some serious cash. Even then, I'm not sure the carbs would clear the frame afterwards as the vboost manifold adds about 4-5 inches to the carb height. You can fit them into a gen 1/2 Venture frame, but it's very tight. I have o basically take the entire carb assemblies off if I want to adjust anything more than idle speed or the idle air mix. It's a major PITA.
I also discovered that the VMax engine doesn't like to run with anything besides the stock airbox in place. One fit under my Venture's tank "cover" but I doubt it woudl fit under the lower RSV cover. They also do a weird thing if you don't have the drain lines routed in a very precise potion. You would think drain lines could just be routed down and away like most bikes, but not the vmax. You have to route the drain lines up and in the airstream of the airbox intake or you get a horrible flat spot somewhere over 20 mph. I chased my tail for months until I was talking with Sean Morley (VMax specialist) one day and he mentioned they were very sensitive to drain hose routing. Moved the line up to the airbox intake flow and the flat spot disappeared. Guess it's just the way Yamy designed it.
You would think just tossing in a VMax engine woudl be a simple matter, but it's not. The frame was changed to accommodate the change in the heads exhaust ports so a gen1/2 engine will not fit the stock frame. I know of one guy who got it done, but it involved major frame alterations. Specifically, the down tubes to head/exhaust area just wouldn't fit because of the differences between XVZ/VMX and RSV heads. he never was very happy with the end product either. It ended up slower and more uncomfortable than a VMAX (if more uncomfortable is even possible when talking VMax).
By the time you get it all done, you would be money and time ahead if you had sold the RSV and bought a VMax. Even with all the changes, the RSV will still be heavier and slower than the vmax, or even the gen1/2 XVZ's.
Also be aware that vmax parts on a RSV is going to make the MPG absolutely tank. My Venture dropped from 38 mpg to 20-25 mpg, and that's even with being very light on the throttle. best I've ever gotten after the conversion is 32 mpg, but i only got that once and was never able to repeat it. The bike is routinely under 30 mpg, if not below mid 20's. Probably because the vmax is not intended to be a MPG master, but a boulevard dominator. MPG takes a back seat to HP in stop light to stop light challenges, which is what the vmax was built for. I will say though, while getting that 20-25mpg the Venture is an absolute monster. When you crank on the throttle, you better be straight up and pointed exactly where you want to go because it's going to get there, FAST! Wheelies and black snakes are only a throttle twist away, anytime, anywhere, any speed and it will bite you.... HARD ....if you're not giving it proper respect.
I never really understood why they "neutered" the yammy V4 for the RSV line. The big V4 Yammy is a rev-er, not a low speed slugger. It wants to spin to make good power, which is pretty much opposite of a cruiser....not to mention the XVZ engines are VERY top heavy. Again, the opposite of what you want in a cruiser. in truth, it wasnt the best touring bike engine either, because of the above mentioned characteristics. It did make for one hell of a high speed mile muncher though. It's happiest when you're wringing it's neck, not lugging along just over idle.
They should have just dropped a big twin in the RSV chassis and called it a day. Lord knows they have enough V-Twins lying around the Yammy design/engineering studios.
If it were me with an RSV, I'd probably just enjoy it for what it is. You get don't get value for the money and effort you have to put out to modify them. But that's only because of the experiences I have with the VMax conversion and knowing how much of a pain it is/was to get it there...
thanks for all that, i guess i'll just leave the big lump of lard alone ( except for some screaming eagle mufflers i've been donated as mine were all smashed in along the bottoms )
i'm still in the process of giving it a really good clean and check over, the PO had lots of extra stuff on it ( including a trailer...) so the wiring needs to be de-fcuked and some of the plastics need fixing
i have however made my vmax comfortable for me anyway, corbin seat so i move back about 4 or 5 inches further, forward controls (which took a bit of getting used to, can't just push down on a footpeg to change lanes and i still forget sometimes and go for the old pegs off the lights) and MX fatbars
its never going to be over comfy for me, i'm 6'5" so it feels like a minibike to ride but i'll never sell it, love it too much
i blame Terry
Offline britman
« Reply #27 on: June 09, 2022, 02:19:33 PM »
My words of wisdom for today:
"750K HEADER SPIGOT SCREWS ARE THE WORLDS BIGGEST PAIN IN THE %$#.  CAME DOWN TO A COLD CHISEL AND HAMMER FOR TWO OF THE LITTLE DEVILS......"
Offline BenelliSEI
  • 1969 cb750
« Reply #28 on: June 09, 2022, 02:47:54 PM »
So true! Careful with that hammer. Years ago, I watched another guy (in my shop, but NOT me) break one of the towers off doing just what you describe! I never reuse those horrible screws. A local supply house (Bolts R Us) had a box of identical, nicely plated screws, except they take a 6 mm Allen wrench. I bought the entire box and I’m only 1/2 way through it! They’re hidden by the pipe clamp, so just perfect.
Offline britman
« Reply #29 on: June 10, 2022, 01:11:13 PM »
[/quote
I found stainless ones with Allen heads at my local True Value Hardware Store.  Stock ones just about wiped out every Philips head in my hand impact driver set.  I don't understand, it is from Harbor Freight, you certainly would expect top notch quality.......
Offline britman
« Reply #30 on: June 14, 2022, 05:14:27 AM »
Opened a fresh tub of elbow grease yesterday.  Still need a little rubbing here and there, but overall it cleaned up nicely.  Me not so much, the Wife is on me constantly about wearing gloves when doing stuff like this.  I will put on a pair if I am up to my elbows in oil, but when doing detailing work or spinning wrenches, I just don't like the way they feel.  It is also not my fault we have white tile in the shower.........
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #31 on: June 14, 2022, 07:48:57 AM »
I wear nitrile gloves a lot. Of course when it comes to small parts they get in the way. I just don't like getting too much stuff on my skin, you never know......
1973 CB 750 K3
10/72 build Z1 Kawasaki
Offline grcamna2
« Reply #32 on: June 14, 2022, 08:14:55 AM »
Oh, that engine came out NICE  8) :) britman !
« Reply #33 on: June 18, 2022, 08:04:46 AM »
Engine transformed like that without leaving the frame?
It look like a complete good restore.
Offline Alan F.
« Reply #34 on: June 18, 2022, 08:52:29 AM »
Wonderful work there!
Back in my manufacturing days I used to run into the odd overtightened, stripped or loctited flat head or button head screw that stopped the show. The trick was to use an automatic center punch in the same fashion as your hammer & cold chisel, but no hammer is needed.
This is the one I had:
https://www.amazon.com/General-Tools-78-Automatic-Center/dp/B00004T7RF/ref=asc_df_B00004T7RF/?tag=hyprod-20&linkCode=df0&hvadid=309763890402&hvpos=&hvnetw=g&hvrand=7469725376507700649&hvpone=&hvptwo=&hvqmt=&hvdev=m&hvdvcmdl=&hvlocint=&hvlocphy=9001887&hvtargid=pla-432012688261&psc=1
Just as nice as the Starret model but with a replaceable carbide (?) tip. It was very good when space was limited.
« Last Edit: June 18, 2022, 08:54:00 AM by Alan F. »
« Reply #35 on: June 19, 2022, 06:33:29 AM »
 I've exploded a couple of those #3 snap on crosspoint sockets on my craftsman battery impact trying to remove exhaust screws. They aren't officially JIS but when they come out the screw is always stuck to the bit. They rarely ever strip one out but on occasion you need to go see the snap on man.
Offline grcamna2
« Reply #36 on: June 19, 2022, 11:18:57 AM »
Now that you mention it Don,I have a Vessel hand impact with a 'twisted' #3 bit that needs replaced;I know a spare #3 & #2 bit will help.I would like to know where a guy can get Vessel JIS bits ?
« Reply #37 on: June 19, 2022, 02:44:04 PM »
Vessel JIS bits for impact are sold on ebay. Motion pro started selling 1/4" hex short bit replacement two pack for their Thandle wrench. I bought all three sizes of those and I have the Vessel Impact Driver. The Harbor Freight Unit suffers from poor quality Chinese steel that is not properly heat treated.
Vessel makes lots of different screwdrivers, all of which are JIS standard. The Ball handle version with the shaft through the handle can be hammered on to shock the screw to break any oxidation that is making a fastener hard to remove. The 750 spigot screws being an extreme case...
The Vessel "Impacta" line of screwdrivers have the ability to back out a screw when hammered in a similar fashion to the impact screwdriver handles.
Offline grcamna2
« Reply #38 on: June 19, 2022, 03:13:18 PM »
I want the Vessel brand quality bits,Made in Japan,not China.
« Reply #39 on: June 20, 2022, 07:42:41 AM »
Offline grcamna2
« Reply #40 on: June 20, 2022, 10:46:07 AM »
Here camna...   https://www.ebay.com/itm/143957468007?hash=item218488a367:g:y84AAOSwfZBiFU7H
Hi Stev-o,I took a look at that listing and it seems 'on target' for what I'm looking for,thanks,Bill  ;)
Offline atm cycles
« Reply #41 on: June 20, 2022, 07:49:10 PM »
Pink with gold flake. From original owner. Early k1. Pretty ugly. I’m getting close to finish
Offline atm cycles
« Reply #42 on: June 20, 2022, 08:08:17 PM »
My take on K1
Offline newday777
« Reply #43 on: June 23, 2022, 03:27:15 AM »
My take on K1
That's the pink one?
Well done if so. Looking good.
Stu
My current rides
Prior bikes....
Offline atm cycles
« Reply #44 on: June 23, 2022, 06:26:40 AM »
Yes same bike
« Reply #45 on: June 23, 2022, 09:55:51 AM »
atm, that points cover is to die for...
« Reply #46 on: June 23, 2022, 11:52:24 AM »
That cover cost a lot where available.
I still have one my K6 got early 80's.  Did not cost much then.
Bad condensors were seen in the evening/night when flashing.
« Reply #47 on: June 23, 2022, 02:43:29 PM »
Looks like member Frankenstuff's...
https://www.fb-stuff.com/fb-stuff-store.html
« Reply #48 on: June 23, 2022, 04:27:51 PM »
Similar, but not exactly the same.  yea, I should get one of his.  Have not bought from him for a long time.
