Author Topic: Fuel Pump Wiring inside a Fuel Cell.  (Read 736 times)
Offline BenelliSEI
  • 1969 cb750
« on: May 30, 2022, 02:26:54 PM »
Installing a 22 gallon ATL fuel cell in the back of the race car. We have two in tank fuel pumps that came with the Lexus. Considering using them INSIDE the cell.....
Does anyone know of a small, liquid proof, bulkhead style connector that I could use to get the pump power and ground leads out through the top plate on the cell?
Offline BenelliSEI
  • 1969 cb750
Re: Fuel Pump Wiring inside a Fuel Cell.
« Reply #1 on: May 31, 2022, 06:40:18 AM »
Found one. McMaster-Carr #7807K11. Threads in on a 3/8” NPT and has a soft rubber core plug with two wire openings. As you tighten the top gland nut, the rubber seals around the wire..... Neat.
« Reply #2 on: June 02, 2022, 10:03:40 PM »
Awesome, it's kind of a strange idea to us old guys but they've done it now for decades.
Offline BenelliSEI
  • 1969 cb750
« Reply #3 on: June 03, 2022, 03:31:00 PM »
Don.... it creeps me out some days. I used to be fairly knowledgeable but lately I discover more and more stuff I don’t know anything about! Yikes!
Offline BenelliSEI
  • 1969 cb750
« Reply #4 on: June 03, 2022, 03:33:11 PM »
Most of these pumps actually drive the fuel right through the electric motor housing to keep it cool!
Offline Tracksnblades1
« Reply #5 on: June 04, 2022, 12:15:40 AM »
Looks like you found an economical solution..
Amphenol makes a lot of Military and Aerospace connectors.
A look in their electrical bulkhead sections, you may find one that is rated for the intended environment.
They’re pricey but they are used frequently when the connection must be reliable…
Age Quod Agis
Offline BenelliSEI
  • 1969 cb750
« Reply #6 on: June 04, 2022, 03:21:55 AM »
Thanks, will have a look.
« Reply #7 on: June 04, 2022, 09:35:23 PM »
 I got a new gas tank for my firebird that was made with a fitting for an in tank electric pump and a separate sending unit. I bought the pump rated for around 600 horsepower, I'm worried it might be too big and heat up the fuel by over pumping.
 The motor will be a Pontiac 400 bored and stroked to around 462 cubic inches or left at 400 with a centrifugal blower.
