Author Topic: PD carb squirter bowl clogged inlet = no squirt , help !  (Read 371 times)
Offline Spanner 1
« on: June 03, 2022, 04:39:34 PM »
Hey fellas. No squirt from the 4 carb squirters because the squirter bowl on #2 carb is not filling due to blocked/stuck/ corroded valve in the bottom. Anyone successfully maybe drilled out the valve and fixed it some way ?
« Last Edit: June 03, 2022, 05:59:17 PM by Spanner 1 »
Offline BenelliSEI
  • 1969 cb750
Re: PD carb squirter bowl clogged inlet = no squirt , help !
« Reply #1 on: June 03, 2022, 06:42:30 PM »
Strip a piece of #14 or #16 solid copper wire (whatever fits best in the hole). Snip the end on a diagonal with wire cutters. Chuck the other end in your variable speed, cordless drill. Leave just enough to get down through the hole, insert and rotate slowly. A short piece of guitar string works even better as a “flexible drill bit”....... Good Luck.
Offline Spanner 1
« Reply #2 on: June 03, 2022, 07:15:34 PM »
Oooh ! Will try that, I think it's just a ball bearing and a seat, right. As the diaphragm pushes down it seals the ball to the seat and as the diaphragm releases up ( by the spring ) it opens the ball for fuel flow from the carb bowl, correct ?
Offline Spanner 1
« Reply #3 on: June 03, 2022, 07:16:20 PM »
Any more ideas ?
Offline BenelliSEI
  • 1969 cb750
« Reply #4 on: June 03, 2022, 07:28:49 PM »
Ultra sonic tank......
Offline newday777
« Reply #5 on: June 04, 2022, 12:29:32 AM »
Yup agreed. Or can of carb soak for 15-20 hrs.
Stu
My current rides
Prior bikes....
