Author Topic: Rear Brake arm for a K1  (Read 572 times)
Offline GLRoberts99
« on: June 06, 2022, 01:46:38 AM »
For some odd reason the rear brake arm was missing off the project bike that I acquired. I can't find them on David Silver Spares or CMSNL and eBay is proving elusive. Any suggestions where I can get the part, or what alternatives will work without looking out of place?
TIA
Gareth
Offline Scott S
Re: Rear Brake arm for a K1
« Reply #1 on: June 06, 2022, 04:28:24 AM »
 Which arm are you referring to? The arm that goes on the backing plate? The pivot arm/rod that goes in the frame? Or the actual foot pedal itself?
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
« Reply #2 on: June 06, 2022, 05:08:25 AM »
Search here for "rear brake arm".
https://m.ebay.com/seller?sid=twowheelspares&_trksid=p2349624.m3561.l49544
Can be the moving arm on brake cover or the arm from swing arm holding the brake cover in place.
The latter available at Yamiya750.com. Chromed or stock style.
The lever used by the foot usually called pedal.
« Last Edit: June 06, 2022, 08:44:01 AM by PeWe »
« Reply #3 on: June 06, 2022, 08:41:59 PM »
I probably have a brake arm, if that's actually what you need.
Offline Rookster
« Reply #4 on: June 07, 2022, 01:10:20 PM »
There are some aluminum options as well as The stock one.
Joker Machine makes one in black or silver https://jokermachine.com/products/honda-cb-rear-brake-strap-black
TTR400 makes one also https://4into1.com/ttr400-rear-brake-strap-silver-honda-cb350-cb400f-cb550-cb750/quote
Scott
Offline BenelliSEI
  • 1969 cb750
« Reply #5 on: June 07, 2022, 01:23:54 PM »
I’ve made my own a few times from a  piece of 1” aluminum flat stock. Radiused the ends and drilled a row of 5/8” holes for a racy look. Polished it up too. I think it went on my “F”. It’s in tension, so almost any material will work….
