Author Topic: CB 750 chain oiler.  (Read 1148 times)
Offline rz350ypvs
CB 750 chain oiler.
« on: June 18, 2022, 05:58:10 AM »
Can someone tell me if i am missing a seal here? I took it apart due to an oil leak and it doesn't look right. The only thing in thr countershaft is s gold coloured "screen".
Sent from my LG-M703 using Tapatalk
CL350
CB400F
RZ350
RD350
S1 500
Offline 69cb750
Re: CB 750 chain oiler.
« Reply #1 on: June 18, 2022, 06:28:57 AM »
You need the rubber seal on end of adjusting screw.
Offline rz350ypvs
« Reply #2 on: June 18, 2022, 08:46:17 AM »
Thanks! I figured something was wrong. Does anyone have a part number? Is it available even? Thanks.
CL350
CB400F
RZ350
RD350
S1 500
Offline 69cb750
« Reply #3 on: June 18, 2022, 11:49:26 AM »
Offline newday777
« Reply #4 on: June 18, 2022, 07:20:48 PM »
Stu
My current rides
Prior bikes....
« Reply #5 on: June 18, 2022, 07:25:27 PM »
https://www.ebay.com/itm/232496268850
That looks like it could be made from a short piece of vacuum hose?
« Reply #6 on: June 18, 2022, 10:30:10 PM »
The oiler plug ends with a triangular shaped washer.
Both my bikes have stock still working. My K6 same since the very beginning and still working.
It has went off-on many times during the years.
It would be handy with a slim stop sealing plug with internal allen.
Never to be removed when lifting front sprocket.
Offline rz350ypvs
« Reply #7 on: June 20, 2022, 04:21:31 PM »
Looks like it's not available anymore, according to two dealers here in Canada. I see i can "block" off the oiler. What are the best options? I was thinking of just buying a bolt that will cover the side hole and just using thread sealer. Anyone tried something like that?
CL350
CB400F
RZ350
RD350
S1 500
Offline Airborne 82nd
« Reply #8 on: June 20, 2022, 09:31:24 PM »
There are post here where people have done just that. Then use a good chain lube. I use PJ1 Blue Label most bike shops and auto parts stores sell it. The lube stays put and works good  Orings or not even in the rain. It is clear not blue.  ??? https://pj1.com/products/
AIRBORNE82nd.
« Reply #9 on: June 20, 2022, 09:52:18 PM »
You mean like this?
« Reply #10 on: June 21, 2022, 12:51:04 PM »
Exactly that one! ;D
The best model I have seen. Plug and forget.
No need to remove it when taking off the sprocket.
No o-ring or other seal needed?
« Last Edit: June 21, 2022, 12:58:52 PM by PeWe »
Offline newday777
« Reply #11 on: June 22, 2022, 03:15:18 AM »
You mean like this?
Where do you get some of these???
Stu
My current rides
Prior bikes....
Offline newday777
« Reply #12 on: June 22, 2022, 03:20:03 AM »
I read a post last week on this and thread sealer on the threads will not stop the flow. You have to plug the hole in the shaft. Unfortunately I didn't save the post.
You can Find it using the search tool above.
Stu
My current rides
Prior bikes....
Offline rz350ypvs
« Reply #13 on: June 22, 2022, 01:18:22 PM »
I made this steel piece and got an o-ring. Maybe it will seal.
CL350
CB400F
RZ350
RD350
S1 500
Offline 69cb750
« Reply #14 on: June 22, 2022, 07:03:25 PM »
What is od of spacer and O ring ?
« Reply #15 on: June 22, 2022, 07:37:13 PM »
You mean like this?
I made that six years ago, as part of my never ending quest to shed weight, as well as block the oiler. ;)
Offline rz350ypvs
« Reply #16 on: June 23, 2022, 08:24:58 AM »
The o-ring was about 12.4 mm which was a little big, but all i had at work. The spacer I made at 11.8mm.  I cut a 45 degree chamfer on the side that presses against the seal. I believe the bore in the countershaft is 12mm, but i didn't accurately measure it.
I went for a ride last night and left it on the side stand.  I guess i will see tonight if it leaked.
CL350
CB400F
RZ350
RD350
S1 500
Offline newday777
« Reply #17 on: June 23, 2022, 08:46:46 AM »
So you put the oring in 1st to the center bore then your milled spacer on the end of the adjuster shaft?
Stu
My current rides
Prior bikes....
Offline rz350ypvs
« Reply #18 on: June 23, 2022, 10:05:03 AM »
Yes, that's what i did.
CL350
CB400F
RZ350
RD350
S1 500
« Reply #19 on: June 23, 2022, 12:05:42 PM »
Scottly, there is no rubber seal/ bottom under that plug? Sealing the oil supply via the porous metal thing and block the hole where oil comes out.
