Author Topic: PD41B Float Bowl Overflow Tube Bodge-up  (Read 1292 times)
Offline Merph
« on: June 21, 2022, 12:40:00 PM »
For those who have seen these carbs before, the nightmare continues!
I removed the Drain screw from the bottom of the float bowl and found the tapered tip had been cut off???
Looking inside the screw orifice the overflow tube had been replaced and fitted right through the section.
See the pics
So now I need to source a replacement overflow tube and drain screw
