Author Topic: Electronic speedo pick up mounting location.  (Read 950 times)
Offline Clivecoo
« on: June 22, 2022, 02:44:40 PM »
I’ve just finished a cb550 street tracker style build.
I used a motogadget pro speedo / information unit.
 I initially thought about mounting the supplied speedo magnet / pick up  on the engine sprocket but decided there was not enough room.
I decided to mount it on the front wheel and the picture shows where I mounted it.
I put the magnet in the edge of the disc that I had drilled to give a modern look.
After drilling the edge and glueing the 4 mm magnet in the hole I routed the cable alongside the brake hose.
After fitting I read that magnets may stop working at temperature’s over 100c.
I’ve since done 500 miles on the bike with no problems  so think it’ll be ok.
Hope this helps others that may be looking for a pick up location.
Offline spotty
Re: Electronic speedo pick up mounting location.
« Reply #1 on: June 22, 2022, 07:14:42 PM »
nice neat solution, i'm thinking i might use a gps speedo when i build my trailbike 750
also nice work with the paint to change the profile of the tank
i blame Terry
