Author Topic: Key Question  (Read 776 times)
Offline John G
  • A 1975 CB Rebuild
Key Question
« on: June 30, 2022, 10:56:01 PM »
OK, Amazon appears to sell new ignitions with keys . I need one of those because I bought a bike with no keys. But; what does one do about the seat key? Do o you think a lock smith could create the keys I need?  :(
John G.
Offline Alan F.
Re: Key Question
« Reply #1 on: June 30, 2022, 11:36:08 PM »
You don't need a new ignition switch, go to a good locksmith with the numbers from your present ignition switch and they'll be able to cut you some keys to fit both your seat lock and ignition.
Offline Gurp
  • I'm no.......
  • Once was a...
Re: Key Question
« Reply #2 on: July 01, 2022, 12:09:16 AM »
Look at your numbers and post in the wanted section here or scroll eBay. I've found keys for my buddy's bikes so they had a spare set before off eBay. Several people over the years have sold keys on the forum as well.
Sent from my LE2127 using Tapatalk
slow Progress 74 cb550.
Poor boy chop 73 CB500 chop
Future project 77 Cb750 Amen Savior
Offline newday777
Re: Key Question
« Reply #3 on: July 01, 2022, 05:15:21 AM »
Welcome aboard John G from NH
Where are you from?
Yes a locksmith can cut a new key. But expensive. Don't buy the cheap replacement switch as they have many failures.  Buy from Honda.
But you can usually find new old stock keys from leftover keys the dealers had(4 keys came with each bike and dealers would keep 2). You just need your key number on the ignition switch face.  (T with 4 numbers if it is the original ignition switch!)
Do a web search or eBay search....NOS VINTAGE HONDA PRECUT KEY T.... (with your key number filled in)
https://www.ebay.com/itm/264999105755
Or honda still has full lockets available with ignition, seat, and fork lock.
#14 35010-374-671
SWITCH KIT, MAIN
 This part replaces 35010-341-702.
Price: $105.50
https://www.southsoundhonda.com/--xpartsstream#/Honda_Powersports/CB750KA_(76)_750_FOUR%2c_JPN%2c_VIN%23_CB750-2540001_TO_CB750-2575894/WIRE_HARNESS_%2b_IGNITION_COIL/b3d05c73-22e7-4620-b018-132301d96b6e/143aefcb-9b8f-4361-8010-5a8222dd1fa2/y
Stu
My current rides
Prior bikes....
Re: Key Question
« Reply #4 on: July 01, 2022, 07:00:49 AM »
+1 ... determine your lock number and buy a key on eBay for $8
Offline John G
  • A 1975 CB Rebuild
Re: Key Question
« Reply #5 on: July 04, 2022, 08:35:16 PM »
I believe my ignition switch is not original. No numbers on the face.
John G.
Offline John G
  • A 1975 CB Rebuild
Re: Key Question
« Reply #6 on: July 04, 2022, 09:20:42 PM »
Oops. I found the numbers.
John G.
Offline John G
  • A 1975 CB Rebuild
Re: Key Question
« Reply #7 on: July 04, 2022, 09:30:36 PM »
My switch numbers are  7M123H. Does that mean it's not original?
John G.
Offline newday777
Re: Key Question
« Reply #8 on: July 05, 2022, 01:27:27 AM »
Most likely that is an aftermarket replacement switch yes. Finding a key for that will be very difficult. And the seat won't match it either. Get the new set I linked above having all 3 new locks and 2 new keys. (Then get a couple new keys made right away from a local locksmith as spares for yourself, as the new honda sets have different numbered keys than the original locks from the 70s(now having fewer numbers and different letter than the Tand 4 numbers of the 70s.) and you won't be able to find new precut keys anywhere.
Stu
My current rides
Prior bikes....
Offline John G
  • A 1975 CB Rebuild
Re: Key Question
« Reply #9 on: July 05, 2022, 10:13:08 PM »
WOW. Hey newday777, So I took the switch to a local lock smith. He made me up three keys. When I got the switch and keys home I tried the new keys on the seat release lock and they worked great, Thanks everyone for your input. Machos Gaseous. Till next time.
John G.
Offline newday777
Re: Key Question
« Reply #10 on: July 05, 2022, 10:15:16 PM »
Was he able do do it by the key code you posted?
Stu
My current rides
Prior bikes....
