Author Topic: classic race gearbox  (Read 880 times)
Offline mad mike
« on: July 01, 2022, 10:20:01 AM »
  Greetings gentlemen,   ...... Help/ advice requested please,  ..... Building a classic race CB750  ... What is the best gearbox, or combination/mix  of standard parts  ? ..... Nova box is,  " a no go"  due to costs at the moment,   and also best final drive ratio  setup ? .... I have a few boxes covering  several years , from early to F1 /2?    Thanks in advance .   Mike.
BELIEVE NONE OF WHAT YOU HEAR, AND ONLY HALF OF WHAT YOU SEE.
Re: classic race gearbox
« Reply #1 on: July 02, 2022, 04:54:07 AM »
« Reply #2 on: July 02, 2022, 06:46:33 AM »
 The f2 gear set comes with the wider output shaft but can be swapped to the older one. On a street/highway bike I like the F ratio with a taller sprocket.
  My old K0 was revving 5200 on the highway yesterday, the cam was loving it.
« Last Edit: July 02, 2022, 07:21:03 AM by Don R »
Offline mad mike
« Reply #3 on: July 03, 2022, 05:57:39 AM »
 Hi Don, .....Thanks for the info.   Best regards.   Mike.
« Reply #4 on: July 03, 2022, 07:59:30 AM »
I have an ongoing engine build that has a later transmission.
It looked so good and not much used so I had to buy it. Complete crank with rods and alternator + starter gear from same engine.
The last gear on outgoing shaft got a K2-K6 shaft + new  ball bearings.
4th and 5th will rev a little bit more than the earlier K.
I think it will it be like 4-5 run 17:18 when using 18:48 sprockets.
2-4 now undercutted so just waiting for a refurbished primary chain hub with new rubber inside.
Later outgoing gear is different and must be used with later transmission.
Photos before gear swap to earlier shaft.
Here K2-K6 shaft with later gear and new bearings mounted.
« Last Edit: July 03, 2022, 08:22:04 AM by PeWe »
Offline mad mike
« Reply #5 on: July 07, 2022, 12:13:21 PM »
Thanks  PeWe .... best regards.   Mike.
