Author Topic: CB750K1 Overheating?  (Read 528 times)
Offline pjandrew99
« on: July 03, 2022, 04:53:32 PM »
Took bike out after working on it for months over the winter. Was hard to start but still had tank of winter gas with stabilizer.
One of the things I did was wrap the exhaust pipes to hide some repaired dents. Also, added baffles to some open mufflers and wrapped those with the fiberglass made for that purpose.
Bike ran great for a few hours. Pulled off a highway ramp and stopped at a light when I took off it got significantly quieter. Went from a slight rubble to a whine. Throttle response felt different too. Not bad, just different.
Got just about home and it would stall when I stopped.  Started it, let it idle and stalled again.
All I can think of is it overheated.
I'm going to check if the fiberglass around the baffle came loose and blocking some of the exhaust from coming out. Although I did place my hand over both pipes and the exhaust was exiting.
Wondering if I should have rejetted. I had soot issues in the past so I did change needle position which solved the issue I had then.
This was very strange. Wondering if anyone else ever experienced this.
Thanks
Current Projects
Honda CB750K1
Yamaha SR250
Honda SL350 K0
Offline craz1
  • CDA, Idaho
Re: CB750K1 Overheating?
« Reply #1 on: July 03, 2022, 10:55:05 PM »
I would start by getting that wrap off the exhaust pipes. Might look cool but keeping a lot of heat from dissipating.
74 CB550,73 Z1900, 74 Z1900, 75 Z1900,
72 XS2650, 73 RD350, 2013 FJR1300, 84 XJ550 YAM
Offline pjandrew99
« Reply #2 on: July 04, 2022, 01:53:45 AM »
Blocked vent in the fuel cap? After a winter of sitting it is not unreasonable to experience some rust occurring on the underside of the tank, especially near the vent. Also, if there is/was rust it could easily be finding its way into your float bowls and blocking the jets.
Get a small clear container and drain each bowl to inspect it for any debris. And inspect the fuel cap and vent for blockage.
This sounds like a good first step. That and fresh gas. Thanks
Current Projects
Honda CB750K1
Yamaha SR250
Honda SL350 K0
