Author Topic: 1978 CB750 K8 High Speed Idle Adjustment  (Read 640 times)
Offline Stransky
« on: July 04, 2022, 04:44:25 PM »
Hello everyone. I'm a new member but not new to Honda motorcycles.
I'm trying to adjust my high speed idle on my 1978 bike. I followed the book: Pull the choke on; turn the adjustment screw until it touches the cam; open the choke and then turn the screw in two full turns. I understand that this is supposed to nudge the throttle open a bit when the choke is on.
My problem is that I can't see that it is doing anything. When I engage the choke, the pin rides over the cam, pushes back the spring and lifts the locknut up. It seems to have no affect on the throttle.
What am I missing? Thanks!
Offline newday777
Re: 1978 CB750 K8 High Speed Idle Adjustment
« Reply #1 on: July 06, 2022, 03:36:05 AM »
Welcome aboard Stransky
I haven't dug into cleaning the 78 carbs of the bike I recently picked up yet and didn't know there was a high idle screw on them. Interesting. I'll have to look closer to this.
I'm used to the 71-76 carbs with no high idle step up.
Stu
My current rides
Prior bikes....
Offline BenelliSEI
  • 1969 cb750
« Reply #2 on: July 06, 2022, 04:08:41 AM »
My K7 and K8 both have the set up you describe. It’s been so long since I touched them, Ican’t comment. I do recall that full choke pull does indeed lift th main throttle bridge ever so slightly open....increasing the idle to about 1500-2000 rpm.
Offline newday777
« Reply #3 on: July 06, 2022, 05:19:12 AM »
I presume that is just while the choke cable is in the up position?
Do you have to pull it out fully and crack the throttle to set the high idle like on the old automatic choked carbs of the 60s and 70s automobiles?
Stu
My current rides
Prior bikes....
Offline enwri
  • So that noise is normal?
« Reply #4 on: July 06, 2022, 07:18:32 AM »
The spring isn't always strong enough to open the throttle against the cables. If you fully pull out the choke, then open and close the throttle, it will stay cracked open.
It's easier to notice the throttle closing when you push the choke back in. The return spring on mine is strong enough to close it and move the handgrip a noticeable amount.
If I pull my choke out and bump the bars, that's usually enough to overcome any sticking to get the high idle happening.
Then again, it never really gets cold enough here to need full choke, so I've set mine to ramp up before the blades close too far. I just use it to keep a slightly high idle until it's warmed up enough to idle normally, without all the richness of a fully closed choke. Consequence of that is about 3000rpm idle if I ever do need real choke action.
« Last Edit: July 06, 2022, 07:22:07 AM by enwri »
77 CB 750 k.. 29 years and counting.
91 TDM 850 (No.34) so comfy and soft
8? XJ 550 meh...
76 XL 350 Super Sport stump puller..
80 XR 200 idiot proof
75 MX 250 b dangerous
