Author Topic: Swing Arm Question  (Read 872 times)
Offline Scootch
  • Someday I'll know what I needed to know years ago
Swing Arm Question
« on: July 13, 2022, 02:08:43 PM »
1970 CB 750 K0
Are these things grease fittings? There doesn't seem to be zerk fittings anywhere in the swing arm. If these are grease fittings can you point me to an attachment for my grease gun? Help me understand how I keep the swing arm lubricated....
Offline cfairweather
Re: Swing Arm Question
« Reply #1 on: July 13, 2022, 02:43:50 PM »
Yes, these are grease fittings and a regular grease gun will work on them.  These fittings get clogged up very easy, so if you cannot get a grease gun to work, you need to remove the axle and clean out the swingarm/axle.   Sometimes they are severely plugged and you may have to replace the grease fittings, which you can still order for a few bucks.  You should make sure you can pump grease through the holes before you reassemble.  Obviously, grease everything before you reassemble everything.
Offline Alan F.
« Reply #2 on: July 13, 2022, 04:53:30 PM »
You can pull those out with a pair of pliers and drill the bore out one size larger at a time until you get to 7/32", then you can tap 1/4-28 threads for a commonly available grease fitting.
Of course you'll need to disassemble the pivot bolt from the bike to do this in order to clean out all of the old grease and new metal chips.
Offline Scootch
« Reply #3 on: July 13, 2022, 05:20:06 PM »
Guys thank you very much for the info !
Offline newday777
« Reply #4 on: July 14, 2022, 03:29:52 AM »
CMS and Yamiya have those grease nipples still if you are doing a full restoration.
https://www.yamiya750.com/index.php?main_page=product_info&cPath=246_251_142_94&products_id=1912
Stu
My current rides
Prior bikes....
« Reply #5 on: July 15, 2022, 12:08:44 AM »
Why not drill and tap 6mm and use 6mm zerks, it is after all a metric bike!
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #6 on: July 15, 2022, 07:56:10 AM »
Just depends on how original a person wants to be.
1973 CB 750 K3
10/72 build Z1 Kawasaki
« Reply #7 on: July 15, 2022, 07:29:51 PM »
I drill those holes with a #2 drill (Ace Hardware) and tap them 1/4-28 (Ace Hardware), then clean out the old grease (pipe cleaner and brake cleaner spray) and thread the new ones in, snug.
Offline Scootch
« Reply #8 on: July 16, 2022, 03:15:34 AM »
Thanks for the input everyone! Yesterday I collected the drill bit, tap and zerk fittings. In the next day or so I plan on attending to this.
I do have a question....  should I be able to pull the existing fittings out with pliers??  Or do they unscrew??  Or??
Offline newday777
« Reply #9 on: July 16, 2022, 03:50:35 AM »
They pull out with pliers. They were just pressed in.
Stu
My current rides
Prior bikes....
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #10 on: July 16, 2022, 07:01:32 PM »
If the swingarm is still on the bike you need to be concerned about getting shavings out.
1973 CB 750 K3
Offline Scootch
« Reply #11 on: July 18, 2022, 10:35:41 AM »
Installed the new zerk fittings. It went quite well. Managed to keep metal chips out from drilling by putting grease on the drill bit. Kept backing the tap up to clear the thread chip. Got concerned a couple times that was having to exert a lot of force on the tap. Didn't want to break it off...
« Reply #12 on: July 18, 2022, 09:53:48 PM »
...I've done that already. I can report it isn't any fun... :(
