Author Topic: What did you do to your non-SOHC4 motorcycle today?  (Read 40435 times)
Offline Kelly E
  • Geriatric Hooligan
Re: What did you do to your non-SOHC4 motorcycle today?
« Reply #125 on: April 17, 2023, 09:34:11 PM »
Thanks, I got the swingarm and a few small parts painted today. Yesterday we got the lower steering stem bearing off with just a punch and hammer. Usually it involves a cutting wheel. 8)
1978 Kawasaki KL 250
1980 Suzuki GS 1100E
1983 Honda CB 1100F
1984 Honda VF 700S Sabre
1990 Moto Guzzi 1000 Le Mans
2005 Harley Davidson Fat Boy
Online Trevor from Warragul
« Reply #126 on: April 20, 2023, 09:43:32 PM »
I bought "stainless steel" mirrors for my Kawasaki H1A. They arrived today. Hmm, a button magnet sticks to the stem and mirror body. Definitely not stainless steel! I have submitted a partial refund request...
*** edit ***
I did some research, and some stainless steels are magnetic. However, these types don't have the same corrosion resistance as non-magnetic austenitic stainless steel...
« Last Edit: April 21, 2023, 05:37:05 AM by Trevor from Warragul »
1971 Kawasaki H1A
1972 Honda CB350F
1976 Moto Morini 3 1/2 Sport
1978 Honda CBX
1997 Suzuki Bandit 1200
1999 Ducati Monster 750
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #127 on: April 21, 2023, 07:44:22 AM »
Yes, they will corrode a little, fairly easy to clean up. Better than flaky chrome in that respect.
1973 CB 750 K3
10/72 build Z1 Kawasaki
Online grcamna2
« Reply #128 on: April 21, 2023, 07:51:52 AM »
Trevor,those mirrors look like(in the pics)standard aftermarket chrome plated steel mirrors,imo.
Their listing said SS ?
Offline jgger
« Reply #129 on: April 21, 2023, 08:33:41 AM »
That is just a low grade stainless. You can find the same thing on kitchen appliances and BBQ. The higher dollar stuff will usually pass the magnet test.
« Reply #130 on: April 21, 2023, 06:22:03 PM »
That's what I reckon. Hopefully any rust spots will buff out. They look nice, and weren't particularly cheap..
1971 Kawasaki H1A
1972 Honda CB350F
1978 Honda CBX
Offline C317414
« Reply #131 on: April 22, 2023, 11:09:01 AM »
Most items made from stainless steel are made from 304 alloy or equivalent.  304 will corrode a bit, but usually the corrosion can be buffed out.  The commonly available stainless steel, that is the most corrosion resistant is 316 alloy.  It is not common to find 316, except for the marine, food processing, etc, industries.
The magnet test works most of the time, but that is not always the case with 316 that has been cold worked.  Cold working, may make 316 magnetic.
Another source of corrosion in 304 and 316 is dirty tools, tools that have been used on carbon steel or iron, sparks or particles from nearby machining of carbon steel, etc.  Carbon steel or cast iron particles will corrode stainless.  If left too long before cleaning, they will compromise the chromium oxide surface on the stainless and will result in localized corrosion.  Many suppliers do not understand this.  They do not have tooling dedicated to stainless only, or they fabricate parts from other metals in the vicinity of stainless.
Offline Kelly E
« Reply #132 on: April 22, 2023, 03:26:14 PM »
Today I'm still blasting and cleaning up the small parts for the 78' KL 250. I have to clean up the wiring harness, connectors and the hand controls. I think I have finished up the repairs but I'm sure I've missed a few things. ;D
As soon as we get some drier weather we can blast the frame and get it painted. It will need plenty of time to dry before assembly. We haven't been able to find a new carb insulator except from CSML for $80 plus shipping from Belgium. We'll keep looking for a bit before we cave in and order it from them.
1983 Honda CB 1100F
Offline Kelly E
« Reply #133 on: April 29, 2023, 07:27:30 PM »
Today we got the 78' KL 250 A frame sandblasted today. It was a beautiful day and I should of been riding but I have to finish up this bike before school gets out. I think I have until June 20 or so. Once I get the frame sanded I will be waiting for a good day to paint it. Then finish cleaning up the wiring harness, reassemble the forks, clean and lube the cables and the hand controls while the paint cures.
1983 Honda CB 1100F
Offline Magpie
« Reply #134 on: May 03, 2023, 09:43:17 AM »
Worked on and the SOHC2, Super Hawk. Replaced the O rings between the carbs, messed about with the old wiring connected to a new after market wiring harness and got it sorted after blowing many 15 amp fuses. However it will start on full choke but won't run if the choke lever is moved a hair off full - like it's starving for fuel. The new O rings should prevent it sucking air between the carbs and head (I'll spray some WD-40 there to see if there's any change), there is good fuel flow, so time to check the primary jets for blockages.
Frustrating but fun to work on it.
« Reply #135 on: May 03, 2023, 09:51:35 AM »
Pick up a 15A circuit breaker and wire it to sub in when having electrical issues. It will trip and easily reset and cheaper in the long run over blowing expensive fuses...
Offline BenelliSEI
  • 1969 cb750
« Reply #136 on: May 03, 2023, 05:41:53 PM »
That usually suggests the idle (slow running) jets or passages are plugged?
Offline Magpie
« Reply #137 on: May 04, 2023, 10:44:54 AM »
Yesterday I went through the carbs, soaked and cleaned the jets, set float levels, one was kind of sticking and a small bend fixed that, blew out all the passages, careful reassembly and it starts and runs nicely! Yahoo!
Offline CycleRanger
  • No comment about being an
« Reply #138 on: May 06, 2023, 02:50:58 PM »
Finally found some local ethanol free gas and spent some time today purging the 550, the CJ360T, and the XL250s. I'll get the XS650 tomorrow. The 750 is already empty with the carbs apart.
Offline BenelliSEI
  • 1969 cb750
« Reply #139 on: May 10, 2023, 05:51:53 PM »
Patience get’s rewarded. Nice!
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #140 on: May 11, 2023, 07:50:32 AM »
Ok, not motorcycles but Honda engines.
I took out my little 2000 and 7500 watt generators and started them, loaded them with a heat gun just to check  them out. They are for any power outages we may have, which is rare. Maui is fortunate, the really bad weather would come from south and east of us and we have the island of Hawaii there to act as a big bumper.
The larger one is dual fuel (I converted it) so I started it on propane. First crank and the Honda engine was running.
The 2000 runs on ethanol free. I put a very small amount in and ran it, easy start. That thing runs a long time on almost no fuel. Great little generator. I can convert it too but I have not bought the kit.
1973 CB 750 K3
Offline Alan F.
« Reply #141 on: May 12, 2023, 02:15:42 PM »
I uncovered my Royal Enfield Interceptor for the first time this season. Changed its oil & filter and did a little cleaning. I have much more to do but I still rode a few laps around the driveway before parking it for the night.
« Last Edit: May 12, 2023, 02:17:51 PM by Alan F. »
Offline C317414
« Reply #142 on: May 12, 2023, 06:58:48 PM »
I've recommissioned all the bikes, except for my wife's Royal Enfield Interceptor.  I just got a oil filter for it, so that's next.
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #143 on: May 13, 2023, 07:57:37 AM »
Great looking bike.
1973 CB 750 K3
Offline Alan F.
« Reply #144 on: May 13, 2023, 09:10:00 AM »
Thanks, I think so too. That engine in a chopper frame keeps haunting my thoughts. I bought a 5-pack of Mahl oil filters from Ebay for about $7.80 each, and Catrol 10-50 full synth Moto oil a 6-pack (Edit: from Amazon) for about $8.80:qt, best deals I could find. Lots of little bike shops in India buy parts directly from RE and ship worldwide on ebay, dealer prices here are insane and wait times are long, it's a no brainer when a good ebayer can get parts to you in 3 to 5 days for what feels like 1980's prices.
Offline Magpie
« Reply #145 on: May 14, 2023, 12:04:21 AM »
Worked on the SOHC2 1965 Benly 150. Laced the new rims with new spokes and worked trueing the front one. Patience grasshopper.  :D
« Reply #146 on: May 14, 2023, 12:47:45 AM »
Looks great Cliff, where a d how much for the rims? I have one I need to do...
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #147 on: May 14, 2023, 07:58:22 AM »
AHHH rim lacing.
A meditation to calm the nerves and block out the world.
1973 CB 750 K3
Offline BallAquatics
    • https://vintage.dennisball.us
« Reply #148 on: May 14, 2023, 03:28:36 PM »
Picked up a set of carbs for the turbo on e-bay. Pretty rough, but they look to be complete. Need to saw the choke rod into pieces as it is so rusted I can't get the carbs apart.....
Dennis...  74 CB550  79 CBX  82 Seca Turbo  2011 CBR  2012 NC700X
Online grcamna2
« Reply #149 on: May 14, 2023, 04:04:07 PM »
Which bike did these come from ?
