Author Topic: What did you do to your non-SOHC4 motorcycle today?  (Read 91400 times)
Offline BenelliSEI
  • 1969 cb750
Re: What did you do to your non-SOHC4 motorcycle today?
« Reply #675 on: November 18, 2024, 06:37:51 AM »
Well done Terry. That bike looks great, and the low dollars make it even better!
« Reply #676 on: November 18, 2024, 01:20:28 PM »
Thanks John, it’s a lovely thing, I’m really looking forward to the next ride. ;D
Online CycleRanger
  • No comment about being an
« Reply #677 on: December 08, 2024, 11:38:01 PM »
Installed a Tytronic electronic advance ignition on my CL350.
It works as advertised, for now.
Offline grcamna2
« Reply #678 on: December 09, 2024, 12:20:51 AM »
Excellent  :)
75' CB400F/'bunch o' parts'
Offline BenelliSEI
  • 1969 cb750
« Reply #679 on: December 12, 2024, 01:20:33 PM »
I do enjoy fiddling with points, gap, dwell and timing….. Having said that, every time I install one of these, I wonder why I bother! Slick.
« Reply #680 on: December 19, 2024, 12:49:55 AM »
I’m reviving the VTR1000F “Streetfighter” build I started 8(?) years ago when I bought a badly crashed VTR1000F with all the plastics destroyed to build a poor mans Ducati S4 Monster, before I eventually bought two S4’s. The carbs and tank got a clean and it fired right up. Just need to install the OEM exhausts and replace the front MC, and it should be good for a sneaky ride. ;D
Offline grcamna2
« Reply #681 on: December 19, 2024, 12:58:16 AM »
Nice.  :)
What did you finally do with those two S4's Terry ?
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #682 on: December 19, 2024, 06:36:42 AM »
Too bad the Tupperware (plastic stuff) is so expensive. Lots of good bikes go without after one small crash or fall over.
1973 CB 750 K3
10/72 build Z1 Kawasaki
Online CycleRanger
« Reply #683 on: December 19, 2024, 09:25:08 AM »
Excellent  :)
Yeah, an FYI about these. The points cover will contact and apply pressure to the pickups if a stock gasket is used.
This is bad and alters the timing and probably will contribute to early failure. The solution is to use a thicker (~3mm+) gasket.
Offline Magpie
« Reply #684 on: December 19, 2024, 09:43:24 AM »
Still a work in progress. Seat is out for a new cover. The swing arm is going to come out to check the bearings and re-grease them then a coat of paint. Exhaust system refurbish to follow.  New throttle cables on Santa's sleigh. Cliff.
« Reply #685 on: December 20, 2024, 02:08:17 PM »
G’day Steve, I had a ‘98 model with all the factory plastics and loved the big “L Twin” grunt, handling and brakes, but the ergonomics didn’t suit me at all, I could only ride it for an hour or so and my back, shoulders and wrists would kill me. I traded it and a couple of grand for a car when I was in Canberra.
A few months later I saw a very badly crashed ‘06 model going cheap (like me) so bought it. It was a stat write off so I couldn’t re-register it, but luckily for me I found a titled frame at a wreckers in Sydney so swapped across all the mechanicals which were good. The bike had slid down the road and hit a pole, so the tank was crushed so badly that it smashed the rear cylinders cam cover underneath. I hope the rider survived.
I purposely didn’t replace the plastics because I bought a special top triple clamp from Germany that allowed me to install higher handlebars, bought a nice tank, Corbin seat and a tiny fairing/headlight unit with indicators built in, replaced the damaged master cylinders with Ebay cheapies, but I actually think it looks pretty good. The PO had spent a lot of money on aftermarket adjustable rearsets, alloy velocity stacks, and manual cam chain adjusters, which are essential for the longevity of these bikes, as the only fault with VTR1000F’s are the failure prone OEM automatic adjusters. It also had Yoshimura slip on mufflers, although one was destroyed in the crash so I had to find another one and adapt it to fit.
Last night I installed some OEM mufflers because the Yoshi’s won’t pass the noise level test when I take it in for a Roadworthy Inspection. While I was trawling thru Facebook Marketplace I saw a Honda Varadero going cheap and contacted the owner and I’m going to swap my Yamaha DT250 for it on Monday. It will need some TLC and a paint job, but should be a great adventure bike, so I’ll paint it black and swap the plate between it and my current one as they’re both 2006 models so the cops won’t know the difference. (I hope)
Ironically I gave up on this project 8 years ago after badly burning my leg on the exhaust, and last night after installing the OEM pipes, I managed to burn it again. From now on, any time I’m working on it I’ll wear long pants.
Bill, I still have both Ducati S4’s. I sold the red one to my son, so Spotty and I are working on the black one, so that my son and I can go for a ride together. Anyway it’ll be nice to finally get the Honda on the road. ;D
« Reply #686 on: December 20, 2024, 11:00:45 PM »
Terry, they make a silver infused cream specifically for burns…it will speed healing of your burn and lessen chances of infection. Silver is naturally antimicrobial
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #687 on: December 21, 2024, 06:50:12 AM »
Lots of projects Terry, It must be that the day is longer south of the equator.
1973 CB 750 K3
Offline Magpie
« Reply #688 on: December 21, 2024, 09:37:38 AM »
Time to tackle the rear end.New wheel bearings ordered, swing arm internals look good after a good cleaning thanks to volume of grease in there. Based on the condition of the rear bearings, front wheel bearings are ordered too. Things have slowed a bit since my wife fell and broke her hip. She tries hard but needs a lot of help around here.
Offline BenelliSEI
  • 1969 cb750
« Reply #689 on: December 21, 2024, 10:22:51 AM »
Cliff…. Sorry to hear about your wife! When my wife shattered her heal a year ago, I didn’t get much shop time for a while. Best wishes…..
« Reply #690 on: December 21, 2024, 01:54:06 PM »
Thanks Steve, the weather is on my side at the moment, I started machining some missing Ducati parts on Friday morning before it got too hot, then had a shower before going shopping for another BBQ and stuff to take over to the mother in laws place for Christmas day’s barbecue, then sat under the cooler vent as it was around 90 degrees, then after dinner still had plenty of sunlight so finished installing the OEM exhaust system to the VTR1000F.
Of course I had to fire it up, and was pleased that it is now close enough to Roadworthy that I can actually get it on the road after hibernating in my garage since early 2016. It’s that old “Make hay while the sun shines” thing, I want to get as many of my projects done or sold before winter. ;D
« Reply #691 on: December 21, 2024, 02:39:54 PM »
Cliff sorry to hear about your wife's hip. Dr tells me they want to replace my right hip...
« Reply #692 on: December 21, 2024, 03:10:30 PM »
Hey John, what model Varadero do you own? I just scored one after looking for quite a while, it’s a project, but should be a great bike to ride! Pics tomorrow when I collect it. ;D
Offline grcamna2
« Reply #693 on: December 21, 2024, 04:39:12 PM »
Look forward to the pics of the Varadero.  :)
« Reply #694 on: December 21, 2024, 07:00:37 PM »
Thanks Bill, will do. Gave my VTR1000F a wash and took it for a ride around the block to dry everything off. ;D
Offline grcamna2
« Reply #695 on: December 21, 2024, 07:40:19 PM »
Terry, did your VTR come with those same front brake calipers stock ? !  8)
« Reply #696 on: December 22, 2024, 02:08:12 AM »
I would have thought not Bill, because my ‘98 VTR1000F had 4 pot calipers but I’m going to pick up another’06 model tomorrow and it had 6 piston calipers too? ;D
Offline simon#42
  • liverpool
« Reply #697 on: December 22, 2024, 06:33:33 AM »
will you get enough air going through the radiators terry? the fairing directs air through on the standard bike , without the fairing the air might pass across the radiator without going through it .
Offline newday777
« Reply #698 on: December 22, 2024, 09:34:19 AM »
I was thinking that earlier also.
Stu
My current rides
Prior bikes....
« Reply #699 on: December 22, 2024, 06:50:06 PM »
Thanks guys, to be honest I don’t know, but it’s got a temp gauge so I’ll take it for a ride and see what happens. Now that I’ve scored a Varadero I might put a fairing back on it and sell it. ;D
