Author Topic: cb750 carb idle problems,so frustrated,, help needed  (Read 486 times)
Offline crxnug
« on: July 15, 2022, 11:06:53 PM »
Im restoring a 1975 b Cb750, When i got the bike it ran and would idle, even though it leaked  fuel from float overflow which turned out to be float valve being installed upside down by previous owner,so i rebuilt carbs, ultra sonic cleaner, check float level, new spark plugs  the problem i having is bike is hard to start and  once started wont hold a idle, does anyone know what the problem could be. im so frustrated right now ,I havent sync the carbs as without being able to idle that would  be a issue. any help on what would be the problem would be much appreciated
Re: cb750 carb idle problems,so frustrated,, help needed
« Reply #1 on: July 15, 2022, 11:32:56 PM »
really not trying to be a smart ass but...have you tried turning in the idle screw?
Offline newday777
« Reply #2 on: July 16, 2022, 02:42:16 AM »
What carb kits did you put in when you rebuilt the carbs? Did you use the kit brass parts?
Stu
My current rides
Prior bikes....
Offline newday777
« Reply #3 on: July 16, 2022, 02:59:26 AM »
Another thought is have you checked for vacuum leaks around the intake boots with light shots of carb cleaner or unlit propane?
Stu
My current rides
Prior bikes....
« Reply #4 on: July 16, 2022, 06:43:50 AM »
I'll give that a +1. Large knurled screw on top of the carb rack.
