Author Topic: Carb rebuild/clean  (Read 695 times)
Offline mvent
Carb rebuild/clean
« on: July 18, 2022, 04:04:32 PM »
Removed carbs from 350F they certainly need to be cleaned after many idle years with dried up gasoline in them. My question, what's general consensus, keep them together or separate them from the rack? Thinking about possible leaks between them.
1973 350F
1976 XLCH
1978 KZ1000
2004 FLSTF
Offline newday777
Re: Carb rebuild/clean
« Reply #1 on: July 18, 2022, 05:51:04 PM »
If you don't take them apart, you won't be able to replace the o rings(12 of them) on the fuel rails between the carbs and will have leaks you won't like.
Stu
My current rides
Prior bikes....
Offline mvent
« Reply #2 on: July 18, 2022, 06:45:31 PM »
Thank you
1973 350F
1976 XLCH
1978 KZ1000
2004 FLSTF
