Author Topic: k1 model fork ears and fork lowers  (Read 454 times)
Offline Shtonecb500
    • Youtube profile
« on: July 18, 2022, 08:56:37 PM »
HI,
have you guys encountered fork lowers with no threaded holes to mount the lower fender support bracket or fork ears that are not drilled and dont' have the small reflectors....I know this model is a late model k1.
« Last Edit: July 18, 2022, 09:34:30 PM by Shtonecb500 »
73/74'' CB500/550 resto-mod - sold
75' 750f 91' cbr f2 swap cafe - mock up
74' 750 chopper hardtail - complete - sold
74' CB750/836kit - Black mix & match - daily rider - always tweaking
71' cb500 K0 survivor - complete
71' K1 - CANDY GOLD/BROWN Winton kit - in process
Re: k1 model fork ears and fork lowers
« Reply #1 on: July 19, 2022, 02:50:48 AM »
Ears could be from model where reflectors were on shell mounting bolts but sliders have to have been modified by po, i thought the k1 had chrome ears not paintef
Offline newday777
« Reply #2 on: July 19, 2022, 04:31:57 AM »
K2 was the start of chrome fork ears and black headlight shell
Stu
My current rides
Prior bikes....
Offline BenelliSEI
  • 1969 cb750
« Reply #3 on: July 19, 2022, 04:38:19 AM »
Looks like the PO modified your fork legs. Likely filled in the hole for the reflector stem too.
K1 definitely had painted fork ears and the small reflectors. Here’s a brown one I did a while back...
Offline newday777
« Reply #4 on: July 19, 2022, 04:45:51 AM »
Look inside the ears for the threaded nut bung.
Stu
My current rides
Prior bikes....
Offline dusterdude
« Reply #5 on: July 19, 2022, 02:58:12 PM »
My august 71 build k1 has the reflectors and the lower fender mounting holes.
Sent from my SM-G973U1 using Tapatalk
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
« Reply #6 on: July 19, 2022, 03:21:41 PM »
 I'd also bet they smoothed over the reflector holes. I'm too lazy to go look, but are the fender threads on the fender brace?  There was a ton of custom work done on a lot of these bikes in the last 50 years.
Offline Shtonecb500
    • Youtube profile
« Reply #7 on: July 19, 2022, 05:57:00 PM »
looks like he shaves them off the fork lowers like some of you said, i havent pulled the front end yet but when i do ill check to see if the reflector hole was just filled over. I have another set of fork legs with the threaded holes so ill use those.
Offline BenelliSEI
  • 1969 cb750
« Reply #8 on: July 19, 2022, 07:34:29 PM »
Note the K1 lowers are the same as K0’s…..
