Author Topic: Greetings from the Hall of Fame city  (Read 1262 times)
Offline EPfiffner
« on: July 20, 2022, 05:33:26 AM »
Yes, I live in the home of the football HOF, but have zero interest in football. My name is Eric, I'm knocking on 47 y.o.
I picked up a '76 CB750A from my FIL, who hadn't been able to ride it. Last time it was registered was '05!
It started out as just get it running, but as with everything mechanical I am starting to fall in love with it.
I cleaned the tank, rebuilt the carbs & accel pump, replaced the intake boots and clamps, rebuilt the caliper and MC, cleaned the coil grounds, re-terminated the plug wires, cleaned and set the points, adjusted the static timing, etc. I have been getting parts from Parts 'n More, (found via this forum) I have been happy with everything.
I planned on selling it. There seems to be a notion that I will get killed on a motorcycle. I'm pretty sure I have my wife convinced to at least let me get a helmet, register it for a year, and go from there.
I have never had, or even ridden a street bike before. However I spent many years riding dirt bikes, but that's been 25 years or so.
So that's some of the story! The bike is really nice to ride (although I have nothing to compare it to). Probably could use a carb sync, but pretty darn smooth!
Thanks for all the info here on the forum.
Edit: added a pic of the bike, it didn't attach the first time.
I had it out last night, its running really well as a whole. At cruising speed it feels like it might be cutting in and out, like a surge OR it could just be wind gust resistance, I haven't figured it out. Had a good time though!
« Last Edit: July 21, 2022, 04:18:51 AM by EPfiffner »
Offline dusterdude
Re: Greetings from the Hall of Fame city
« Reply #1 on: July 20, 2022, 02:12:36 PM »
Welcome
Sent from my SM-G973U1 using Tapatalk
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
Offline MD
  • Living in the North Woods overlooking The Lake.
    • MN North Woods
« Reply #2 on: July 20, 2022, 03:08:38 PM »
Welcome from NE Minnesota,
Those dirt riding skills can be handy on slippery roads.
-MD
1975 CB550F Super Sport;  Lake Superior Circle 1000, 45-90 Saddle 1000, All in Yooper 1000 and SS 2000 in 48 hrs:  1985 GL1200A, MN in State SS1K
Offline newday777
« Reply #3 on: July 25, 2022, 03:42:08 PM »
Welcome aboard Eric
It looks like your fil kept it well.
Stu
My current rides
Prior bikes....
« Reply #4 on: July 25, 2022, 03:51:21 PM »
Welcome from Texas.   Yes, get a helmet as when riding, remember that other drivers will not see you so ride defensively.  Have fun!
Offline EPfiffner
« Reply #5 on: August 05, 2022, 07:44:32 AM »
Welcome aboard Eric
The bike does seem to be in good shape. It had a wind jammer and side hard bags that I have removed.
It's a shame that it's been repainted, but it's been indoors for years so things seem to be cleaning up.
Someone has been in to the engine, at least the cam cover, because the screws are rounded/stripped. You wonder what the history is..
I have since picked up a helmet, and I try my best to heed the advice about other drivers. I originally hoped to use the bike to commute back and forth to work and save gas, but the way people drive i certainly am not feeling up to the highway!
Offline tool14
« Reply #6 on: August 05, 2022, 11:25:40 AM »
welcome aboard
Offline wolf550
« Reply #7 on: August 05, 2022, 06:55:03 PM »
welcome from TN. going to be visiting up in Dayton tomorrow for a 350F. Hope the weather is good.
74' CB550 (Sold)
71' CB500/550 (Sold)
Offline grcamna2
« Reply #8 on: August 05, 2022, 07:18:04 PM »
Welcome to the group Eric  :) There's a bunch of good members here who have 99.9% of the answers you'll need:just ask  ;) I like your 750 Automatic,it looks well cared for.
Do you have new tires on it? if not I highly recommend you have a look at the sidewalls,date codes,etc. on them.
Offline EPfiffner
« Reply #9 on: August 08, 2022, 06:58:53 AM »
The tires are not new, and I really should've already checked the date codes instead of just riding it around. I know better than that: Being frugal is one thing, but safety should be paramount.
Offline EPfiffner
« Reply #10 on: August 08, 2022, 07:08:18 AM »
I had a go at syncing carbs a couple weeks ago. I ordered a cheap 4 gauge setup (knowing what I was getting). After reading about it first I calibrated each gauge with the idling manifold vacuum on one of my cars.
Here's the makeshift setup. They were pretty far out, the bike idles sooo much better (not sure if the syncing affects the entire range or not).
The gauge in cylinder 3 seemed much more fluttery than the others, but I was able to eyeball-average it. It could be the cheap gauge, or since the bike sat so long I think it's feasible that I could have a valve not sealing properly.
I figured I'll put a few miles on it and revisit.
Offline EPfiffner
« Reply #11 on: August 08, 2022, 07:30:10 AM »
I was out riding this weekend and I didn't think I was gonna make it home! I thought it was a fuel delivery problem the way it felt.
During my troubleshooting I checked the pipe temps with my laser. 2 and 3 were a bit cool so that got me thinking about ignition.
I pulled the points cover and sure enough, the set of points for 2-3 were sparking like crazy!
I took out the new condensers that I got from Parts 'N More, put in the OEM's, and she's running great again.
That was a learning experience, now I know what to expect with a condenser failure. Good thing Honda split the ignition or I'd have been hoofing it.
« Reply #12 on: August 08, 2022, 08:32:04 AM »
Lesson learned - dont use crap aftermarket parts!  Been there...
Offline Johnie
« Reply #13 on: August 08, 2022, 08:33:03 AM »
Welcome. Just an after thought...be sure to put a fan on the front of the engine when you sync. Don't want to over heat that motor. A good rule of thumb which has kept me out of trouble...don't trust anyone on the road. If a driver is looking you in the eyes...don't trust that he sees you or will wait for you. Last...stay out of the cars blind spots. Might want to consider taking the cycle safety course. Never to good to take it.
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline Gurp
  • I'm no.......
  • Once was a...
« Reply #14 on: August 08, 2022, 09:25:13 AM »
Clean machine!
I'm also a buckeye.
You're a few hours north of me up there in Canton.
slow Progress 74 cb550.
Poor boy chop 73 CB500 chop
Future project 77 Cb750 Amen Savior
Offline EPfiffner
« Reply #15 on: August 08, 2022, 03:52:07 PM »
And you know, the only reason I ordered the condensers was to bump my order enough to get free shipping! I do electronics for a living so I thought "well a condenser is a capacitor, and capacitors go bad with age" so yeah, lesson learned.
Ah, I forgot to mention I had a furnace squirrel cage blower running at the front of the bike during the syncing. Definitely important!
'70 Chevelle in your sig, man do I love those!!
Cool, well enjoy the back roads down south!
Clean machine!
I'm also a buckeye.
