Author Topic: 77 CB550K Fork Rebuild  (Read 413 times)
Offline Maraakate
« on: July 20, 2022, 09:36:08 AM »
Hello,
Both forks are really starting to weep so it's time to change the seals.  I have all the parts, read the FSM many times over, and have looked around on here and other places for advice.  I think I can do this job just fine on my own.
However, before I get started I will need something to drive the seal in.  What's the proper size PVC Schedule 40 pipe you guys are using so I can run out and get this before I start tearing things apart?  Failing that, what size of the motion pro fork seal driver tools would be appropriate to use?
Thanks!
1977 CB550K
1979 CM400A
Offline Bankerdanny
  • Endeavor to persevere
Re: 77 CB550K Fork Rebuild
« Reply #1 on: July 20, 2022, 01:21:38 PM »
The fork tubes are 35MM OD if I recall correctly, which is about 1 5/16" so 1 1/4OD pipe should work. In my case I have a 30MM socket that I use.
Offline Maraakate
« Reply #2 on: July 20, 2022, 01:25:10 PM »
I just measured the total size of the seal it's 48mm.
1977 CB550K
1979 CM400A
« Reply #3 on: July 20, 2022, 03:04:38 PM »
In a pinch you can use an old seal as a driver of sorts which is what I usually do..
« Last Edit: July 20, 2022, 03:12:51 PM by ekpent »
« Reply #4 on: July 20, 2022, 03:40:25 PM »
1 1/4 is smaller than 1 5/16 so would go down the inside of the seal, you need something near to the od of the seal
Offline Bankerdanny
« Reply #5 on: July 20, 2022, 06:09:31 PM »
You are correct sir. 1.5" is probably a bit too small even based on the seal design.
Offline Maraakate
« Reply #6 on: July 29, 2022, 10:33:01 AM »
I just went ahead and used the old seal to drive the new one in.  Placed a block of wood on top of the old one after I cleaned it and oiled both seals with some of the fork oil and drove it home.
I put 145cc in there, I forget where this number came from but it was marked on my bottles for this project.  Probably read it on here, somewhere, at some point but I don't remember.
With that said, I looked at the books and there is conflicting information.  FSM says about 160cc in one place, 185cc in another.  Clymer has the same silliness.  OM said about 155cc if I remember correctly.  Is 185-190cc the correct amount to pour in when completely draining the forks and the ~160cc is when doing regular maintenance to swap the fluid?
I also have a fork oil gauge tool.  Have not used it before, but if this helps accuracy I could use that instead.  Mine is 1977 so not sure if things changed between years.  Forks work better than they ever have, and no more leaks so I'm pretty satisfied; but would like to have the proper amount in there.
1977 CB550K
1979 CM400A
