Author Topic: 1973 CB500K2 clutch adjuster is seized  (Read 550 times)
Offline michaelmegliola
« on: July 31, 2022, 02:45:49 AM »
My clutch adjuster is seized.
I have removed the left-side engine cover (see photo), I can't tap the adjuster through the case to remove it. Penetrating oil does not seem to help.
I know that part is hard to find, so am trying not to do any damage, am I missing something? Or any tricks to get it free?
Re: 1973 CB500K2 clutch adjuster is seized
« Reply #1 on: July 31, 2022, 07:53:48 AM »
There is a seal on the inside, then use a piece of hardwood dowel on the adjuster and hit that
Offline jgger
« Reply #2 on: July 31, 2022, 08:07:02 AM »
Dawn dish soap (the original) will loosen up caked and dried up grease. So if it's old grease gluing it in place give it a good soak. It surprisinglyworks better than most other products. Mix about 50/50with water.
« Last Edit: July 31, 2022, 08:09:19 AM by jgger »
Offline jgger
« Reply #3 on: July 31, 2022, 08:08:27 AM »
Hit the wrong button,  story of my life!
« Last Edit: July 31, 2022, 08:10:46 AM by jgger »
Offline flatlander
« Reply #4 on: July 31, 2022, 11:43:12 AM »
if you can't knock it free with bryan's method, soak for a longer period (over night, 1 day...) with a 1:1 mix of acetone and atf.
« Reply #5 on: July 31, 2022, 12:25:08 PM »
Thanks (all) -- here is what worked: overnight with lots of blaster oil, put in freezer for 1 hour (probably did nothing), then tap out using same-size socket against face of part (kind of like pressing in a seal).
Offline flatlander
« Reply #6 on: July 31, 2022, 10:47:29 PM »
good you got it out, congratulations!
