My bike was a bit of a frankenstein when I got it, with the quite common Harley rear rim swap, Vetter fairing etc. Way back when I first made it road worthy in 2012, I remember buying a master cylinder rebuild kit, disassembling the crusty old MC, lining up all the parts, and finding that the piston was completely different. Mine was replaced by something with a built in brake light switch, so there is no pressure sensor in the brake line. That is steel braided right down to the caliper. Anyway, it's leaking a bit, and I'd like to get a proper rebuild kit, but I'm having trouble IDing it. Here are some pictures:
https://i.imgur.com/tbC34Ur.jpghttps://i.imgur.com/184d56O.jpgThe stamping on the bottom is a little hard to make out. It's 2 K 2 and then Ø 14, which I'm guessing means 14 mm diameter. I believe the rubber parts from the rebuild kit I bought fit, and I just reused the piston.
Any help would be appreciated. Thanks!
