Author Topic: Dunstall Tank Petcock - Petcock - K1?  (Read 2601 times)
Offline jonbuoy
    • My rebuild:
« on: March 07, 2007, 12:25:52 PM »
Hi,
I have just bought a genuine Dunstall tank for my CB750, it didn't come with a petcock/fuel tap.  My petcock has a threaded fitting (F2), I have looked for adaptor plates but can't see any that will fit for the thread spacing I have - here is a drawing.  Could someone tell me if this is the same footprint as a K1 petcock?  Or any ideas what might fit or will I have to drill and helicoil (is this the best thing for fibreglass?)   ???
Cheers
John
Offline doug_id
    • My Cafe 550 Project Gallery
Re: Dunstall Tank Petcock - Petcock - K1?
« Reply #1 on: March 07, 2007, 03:16:57 PM »
I think you need one of these petcocks along with the mounting screws and fiber washers.......
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&ih=010&sspagename=STRK%3AMEWN%3AIT&viewitem=&item=200063396142&rd=1,1
02 Concours
78 CB550
06 Stella 150 2t Scooter
Wis
« Reply #2 on: March 07, 2007, 04:24:50 PM »
that's also the type of petcock from early 550's......for what it's worth.
Offline jonbuoy
    • My rebuild:
« Reply #3 on: March 07, 2007, 05:47:18 PM »
Thanks Guys,
It would be nice to get those dimensions off of one, I wonder how it does reserve with only one pipe in the tank?
Offline doug_id
« Reply #4 on: March 07, 2007, 05:57:11 PM »
I think how it works is the middle pipe does not seal in its hole so when the gas drops below that level and you switch to reserve it just pulls from the gas that comes into the petcock around the tube and the middle hole in the tank.  I cut my tube shorter though as I thought it was pretty long.  + I never run out of gas on my bike....knock on wood.   ;)
« Last Edit: March 08, 2007, 05:24:29 AM by doug_id »
02 Concours
78 CB550
Offline doug_id
« Reply #5 on: March 07, 2007, 05:59:14 PM »
BTW I have an extra petcock still in the wrapping(brand new) if you want to buy it for a discount over what you will find them selling for on e-bay.   I bought another one when I thought my original one was broken......good thing I like to buy high and sell low....!   ::)
Doug
02 Concours
78 CB550
Offline Roach Carver
« Reply #6 on: March 07, 2007, 07:09:17 PM »
Doug
Doug, if jonbuoy doesnt want it, give me a shout. Thanks.
Offline jonbuoy
    • My rebuild:
« Reply #7 on: March 07, 2007, 11:54:45 PM »
Hey Doug,
Thanks for the offer - I appreciate it  -but being on the arse end of the world is a pain when it comes to shipping costs for single items, I'm going to put an order into Dave Silver for my engine parts so I will probably order from him if I get one.  At the moment I'm thinking of a plain pipe fitting with a jubilee clip and an inline gas tap.
Cheers
John
Offline chung
  • Giddy Up
    • chungfucycles.com
« Reply #8 on: March 08, 2007, 03:09:30 AM »
Doug has the pic of the proper piece. It is common among aftermarket tanks. It takes an oval O-ring to seal it against the tank and a couple M6x1x30? screws with sealing washers. The whole rebuild for one is about $20-30 american.
The two outlets for fuel supply to the carbs are very important. One line will not supply a thirsty engine.
I hate it when I have to back peddel in third gear to let the motor catch up while my snooooootty opponent has his front wheel in the air with an arrogant grin on his ugly mug. Present company excluded, of course :-*
Member#2815
1971/76 CB750 Hack @970cc,
1975 CG750K
1970 CB350,
1972 YDS7, 250
1972 YR5, 350
1977 RD400,
1978 Piaggio Grande/Batavas HS50 Special
1981 XS650 Special II
« Reply #9 on: March 08, 2007, 08:11:11 AM »
Dave Silver sells em new for £18 which is cheaper than Ebay!
Offline canttuckmyshirt
« Reply #10 on: March 08, 2007, 08:33:28 AM »
This is great info!
So, will both a 500/550 and the 750 petcocks work?
You also said that we would need both outlets. Any one have a simple source for a replacement barbed outlet?
72 CB500, Abe Henry wheels
77 CB550, resto-mod
04 S2000, LS1 V8
Offline jonbuoy
    • My rebuild:
« Reply #11 on: March 08, 2007, 11:33:30 AM »
I was thinking of braizing a pipe though a metal plate, I wasn't planning to use a barb unless I have to - they can be stubborn to get off again - I would be  worried about tearing it out of the fibreglass.  The two fuel outlets from the standard K fuel tap might be an issue as I have a single feed to my carbs.
Cheers
« Reply #12 on: March 11, 2007, 08:02:00 AM »
Connet both outlets to a "T" piece and use the third leg to connect to your carbs, this is the only tap that will fit this tank to my knowledge--that is why the later Dunstall kits were just a think tank "cover" not a complete tank
Offline jonbuoy
    • My rebuild:
« Reply #13 on: March 11, 2007, 12:26:22 PM »
Thanks,
That might be a neater solution than having a seperate fuel tap and filter .
